416 stroker
#1215955
04/15/12 02:28 AM
04/15/12 02:28 AM
Posts: 9 walton ny
woody30
walton ny
Hey guys, I've got a chance to buy a 416 stroker motor that was started but not finished as the poor guy passed away. Seems like a very good start to a nasty Camaro stomper. It has all the block work done (cleaned, magged, oil galleys cleaned, bored .030, align honed, ARP main studs), an Eagle 4340 forged 4.00 crank, Eagle H beam forged rods, Ross 4.070 forged pistons (12.5 to 1), MP 280 .509 solid lift cam and lifters and a MSD electronic distributor. Pistons seem a bit high on compression for a street car. I would rather get back to 10:0 or 10:5 to 1. Would I have a hard time selling these pistons?? They are $600.00 in Summit. Brand new in the box. Could I get $400.00 for them do you think?? Also is this cam ok for this set up. I have a 6 pack set up I was going to use on my 340 that I would use now on this. What do you think???????????????
Re: 416 stroker
[Re: boydsdodge]
#1215959
04/16/12 02:18 AM
04/16/12 02:18 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
If you are getting a good deal on the motor, and its still a good deal if you have to buy new pistons, id go for it. Like most things you never know what something is worth to anyone else but ebay could be good place to get rid of the pistons. I have not run the calculations but depending on the choice of heads, head gasket thickness, rods they may be just right for someone.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: 416 stroker
[Re: finadk]
#1215960
04/16/12 02:29 AM
04/16/12 02:29 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
See if E-85 fuel is available in your area..
105 octane..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
