Help...ID these oil pick ups #1215340
04/13/12 03:11 PM
04/13/12 03:11 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Can anyone identify theses oil pick ups.
The one on the right I believe is for a 340.
The one in the middle is very close to another one that I have that came out of a 1964 383 engine.
The one on the left, I have no clue to what it goes to.
Re: Help...ID these oil pick ups [Re: rarefish] #1215341
04/13/12 04:47 PM
04/13/12 04:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Right and middle are big block , left is possibly smallblock.
Right looks like pickup for the 187 C body pan or the 70-72 440 4bbl HP engine , depends on length , middle LOOKS LIKE the 4qt sump pan , 402 , from 68 -70 B body/ E body with a baffle.
Re: Help...ID these oil pick ups [Re: JohnRR] #1215342
04/13/12 06:03 PM
04/13/12 06:03 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
A few years ago I took apart a 1967 440 out of a C-Body. I just look in the garage and I have a 187 pan hanging on the wall so I would guess that the one on the left probably came from that motor.
Were the pick-ups used in a 440 from a B-Body different that the C-Body ones?
Re: Help...ID these oil pick ups [Re: rarefish] #1215343
04/13/12 06:54 PM
04/13/12 06:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the one on the right is for the 187 pan .
Yes the 440 B body pickup is different than a C body , 68 and 69 , maybe 67 ?? , used one that looks like the middle one , it's bent to clear internal pan baffles.
