Putting a 360 in a 1965 C Body? #1215249
04/13/12 11:10 AM
04/13/12 11:10 AM
Savannah, GA
mopar400 Offline OP
mopar400  Offline OP
Savannah, GA
I have a 1965 Ply. Fury II. I'm thinking about putting a 1972 360 SB in and have a couple questions. Does anyone know if the Poly 318 engine mounts and trans. bellhousing will work with the 360? Also what exhaust manifold will I need to use? I would prefer headers but can't find any listed. Any tips or help will be appreciated!
Thanks, Kevin
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: Putting a 360 in a 1965 C Body? [Re: mopar400] #1215250
04/13/12 12:23 PM
04/13/12 12:23 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The poly is still a small block. The 360 should drop right in, except the exhaust.
Might wanna go to the C-bodydrydock forum to get more info on your 65 as it was a one year only deal on a lot of things.
http://cbodydrydock.com/forum.php
I have mechanical Aptitude.
I can screw up anything.
Re: Putting a 360 in a 1965 C Body? [Re: mopar400] #1215251
04/13/12 12:24 PM
04/13/12 12:24 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Mostly bolt in/up.
The bell is the same, don't forget the 360 is externally balanced.
The left motor mount engine bracket will need a little bit of ingenuity,nothing too tuff.
Can't make a header recommendation, shouldn't be too much of a problem though.
Radiator outlets will be wrong, unless you change the 360 front to the earlier 318 water pump.
Did this once on a 64, not much problem.
It takes gasoline to interest me.
