double valve springs? #1215096
04/12/12 11:48 PM
04/12/12 11:48 PM
close enough to branson, mo
razorback Offline OP
i took the heads off of a mid 80s dodge 360 motor and i noticed the vavles had two springs, and the valves were completly flat on bottom, with no dimples. were these stock or did someone do some work on these?
Re: double valve springs? [Re: razorback] #1215097
04/13/12 07:51 AM
04/13/12 07:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Sounds like some one has been in it before. If the inner spring has flat coils it is a damper not a spring.Some hi performance engines came with dampers.
Re: double valve springs? [Re: MoparforLife] #1215098
04/13/12 08:19 AM
04/13/12 08:19 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have seen mid 80`s 360`s that have a dampner, its not a double spring, unless someone changed it out. if the inner "spring" is flat, not round its a dampner, not a spring.
