Re: New Engine build-Timing Question
[Re: Publicbottle]
#1214031
04/11/12 12:07 PM
04/11/12 12:07 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
TDC on compression stroke, and point the slot toward the very left front intake bolt. If you are looking straight down and distributor in the back, it would be approximately 5:30 on a clock.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Publicbottle]
#1214032
04/11/12 12:20 PM
04/11/12 12:20 PM
RapidRobert
If the crank has not been turned from when it was dot to dot when built, clock the inter gear/shaft whereever it needs to be so it locates the rotor rearward and slightly to the DR side and place the #6 plug wire there & route them on around CW. This maintains the OE plug wire diagram & lets the wires nestle neatly & be as short as possible. turn the crank slightly back so the timing marks are at 10BTDC (mild cam) and 15 (wild cam) and the vac can is located on the pass side and has room to be turned and the magnet is dead even w the reluctor tooth that locates the rotor under #6 & lightly snug the housing & you're set. If the timing marks are at TDC #1 compression (firing) (6 & 12 o'clock on the dots), then clock the rotor forward and slightly to the pass side & locate #1 plug wire there and same as before back up the crank slightly to 10 or 15 BTDC. and route the wires on around clockwise 1-8-4-3-6-5-7-2. Keep in mind you want to turn the eng by hand as little as possible to keep from wiping the lube off of the lobes. initially locating the intergear slot parallel or the front edge slightly to the dr side will get you close then go from there
[Re: Publicbottle]
#1214034
04/11/12 01:04 PM
04/11/12 01:04 PM
RapidRobert
with the timing marks on TDC either #1 or #6 cyls' rocker arms will be loose which will tell you which cyl is firing (loose is firing)
[Re: Publicbottle]
#1214035
04/11/12 01:51 PM
04/11/12 01:51 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Unfortunately the crank has be turned
Don't lose any sleep over this. Why anyone would even bother to bring this up is beyond me !!
[Re: Publicbottle]
#1214037
04/13/12 04:32 PM
04/13/12 04:32 PM
RapidRobert
back up the crank slightly to ~20 then slowly forward to 10 or 15 BTDC (takes slack out of the chain). Turn dist till magnet is dead even w the nearest tooth that places the can in the general vicinity where it goes and whatever cap terminal is over the rotor is now #1 but I would strongly suggest clocking the inter gear so the rotor is forward and slightly to the pass side no matter where this makes you clock the hidden intergate slot at (& OE as you did may be fine). Some dizzy's have a different bottom shaft tang to top rotor phasing which requires a different than the shop manual intergear clocking picture if you want to maintain the OE plug wire diagram which is highly recommended (helps prevent future errors) & lets the wires route as short as posssible & nestle neatly. Gap the reluctor to .008 w a brass feeler gauge.
