71 Roadrunner Horn Switch #1212602
04/09/12 11:30 AM
04/09/12 11:30 AM
Saint Charles, MO
GTXTSY Offline OP
GTXTSY  Offline OP
Saint Charles, MO
I need to replace the horn switch on my 1971 Roadrunner....where are the screws located that allow me to remove the steering wheel pad to access the horn switch?
Re: 71 Roadrunner Horn Switch [Re: GTXTSY] #1212603
04/09/12 12:22 PM
04/09/12 12:22 PM
NJ
rth Offline
rth  Offline
NJ
depends on which wheel you have. tuff wheel the cap snaps on,other wheel look behind spokes if no screws then gently pry off.what do you mean "horn switch"?horn contacts are part of turn sig switch. horn switch would be in steering wheel pad.did you check fuse and relay?
Re: 71 Roadrunner Horn Switch [Re: rth] #1212604
04/09/12 01:19 PM
04/09/12 01:19 PM
Saint Charles, MO
GTXTSY Offline OP
GTXTSY  Offline OP
Saint Charles, MO
I have the wheel with the 3 horn buttons......horn sounds when I jump it.....fuse is good......is relay on fuse block?
Thought it would be similar to my E body with the switch in the column....thx
Re: 71 Roadrunner Horn Switch [Re: GTXTSY] #1212605
04/09/12 01:34 PM
04/09/12 01:34 PM
NJ
rth Offline
rth  Offline
NJ
not sure on relay location,might be under dash left of column.should have three prongs.one lead to horns,one 12v ,last ground from column.quick check is use test light,clip grounded ,go to column harness connector.usually a blk wire,touch probe to backend of connector.relay will get grd through t/light and blow horn.a simple tip on elect problems "kiss it" meaning, keep it simple stupid. we tend to over think and pull thing apart before simple steps.please don't misinterpet,not insulting anybody just passing on what works for me.
Re: 71 Roadrunner Horn Switch [Re: GTXTSY] #1212606
04/13/12 07:37 AM
04/13/12 07:37 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
On the backside of the steering wheel
