'71 Duster come with both 2 and 3 Speed Wiper Motor? #1212387
04/08/12 06:56 PM
04/08/12 06:56 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
On a '71 Duster,was a 2 speed and a 3 spped wiper motor available?Non-rally dash if that makes a difference.Thanks
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212388
04/08/12 07:02 PM
04/08/12 07:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212389
04/08/12 07:44 PM
04/08/12 07:44 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I did install a variable speed wiper on one of my 71 Dusters that i had because I needed the extra room to install my six pack air cleaner. The wire harness is the same, you just need the switch and the wiper motor.
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212390
04/08/12 08:54 PM
04/08/12 08:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, both were available, 3 speed was an added cost option
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: ScottSmith_Harms] #1212391
04/08/12 09:05 PM
04/08/12 09:05 PM
I see they make a reproduction wiring harness for a 2 speed motor but not a 3 speed .Is the correct plug in for a 3 speed motor part of a different harness?
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212392
04/08/12 09:08 PM
04/08/12 09:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it has it's own harness
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: ScottSmith_Harms] #1212393
04/08/12 09:19 PM
04/08/12 09:19 PM
So the 3 speed harness is not being reproduced? I don't see it listed in Year 1 or is it part of a main harness unlike the 2 speed which looks like it's seperate and plug directly into the bulkhead?
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212394
04/08/12 09:33 PM
04/08/12 09:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Call M&H harmess, I just discussed this topic with them at length. They can suggest the correct part# to order from YO.
Darrin Grove
M&H Electric Fabricators
13537 Alondra Blvd.
Santa Fe Springs, CA 90670
Phone: 562.926.9552 x205
Fax: 562.926.9572
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: ScottSmith_Harms] #1212395
04/08/12 09:40 PM
04/08/12 09:40 PM
Thanks for the info Scott.Hope you don't mind,but I'll be tapping into your A body knowledge for the next few weeks.I'm helping a buddy out with his '71 Duster.Thanks again
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212396
04/08/12 10:12 PM
04/08/12 10:12 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
"The wire harness is the same, you just need the switch and the wiper motor."
You also need the 272 cam arm and the tan colored bushing. The black 2 speed bushing will not work as well as the cam arm from the 2 speed.
Typically 3 speed motors come with their harnesses already installed. They are not plug in type to the motor.
Jules
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: JulesdaWiperman] #1212397
04/08/12 10:19 PM
04/08/12 10:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's what I was trying to say
The underhood wiring varied A BUNCH depending on where the car was manufactured, I have been discovering all sorts of little wiring differences with Los Angeles built cars!
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: ScottSmith_Harms] #1212398
04/08/12 10:42 PM
04/08/12 10:42 PM
The problem I think I may have is somebody installed a 3 speed motor into this Duster and I think it originally was a 2 speed.How can I tell if they changed the linkage/bushings/etc to work with the 3 speed?If I find out they didn't change over anything,I'll just switch it back to a 2 speed.It never rains in MN any more anyways
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: 44D6PAKCUDA] #1212399
04/09/12 09:43 AM
04/09/12 09:43 AM
super gas
super gas
The linkage and pivots stay the same.
The cam arm should a part number ending with 272 for a 3 speed.
The bushing on the cam arm should be tan colored for a 3 speed.
It is black for a 2 speed.
Jules
Re: '71 Duster come with both 2 and 3 Speed Wiper Motor? [Re: JulesdaWiperman] #1212400
04/09/12 10:09 AM
04/09/12 10:09 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2 speed crank arm bushing on the left versus 3 speed crank arm bushing on the right
