92 Dakota overdrive question. Should be simple.
#1211912
04/07/12 06:22 PM
04/07/12 06:22 PM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Hey fellas, my buddy has a 92 Dakota, V-6, A-500 OD trans. Good little truck, 140,000 miles. Trans works fine, and always has up until recently. It wont shift into overdrive. The light on the button works.
My advice was first to clean the plug on the transmission. Im not sure where to go next. If I remember correctly, the 92 OD trans was not computer controlled. Just a "on/off" switch that supplied or took away power to the overdrive unit. The button has 6 wires though.
Anyone have any advice? Anyone know which wires you would need to use to bypass the switch to check it?
Thanks fellas,
Laine.
NRCA Member
Re: 92 Dakota overdrive question. Should be simple.
[Re: Lmopar69]
#1211914
04/08/12 12:58 AM
04/08/12 12:58 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Should have 12v to the transmission center pin always, unless the OD cancel switch is engaged. The computer grounds the 2 outer pins to control LU and OD.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Lmopar69]
#1211916
04/08/12 12:59 PM
04/08/12 12:59 PM
herkamer
Lakewood, Colorado
Yes, you could ground each side through a switch and it should function but you will need the 12v first. No idea where it gets the 12v from, whether it is the PCM or through a relay or fuse.
[Re: herkamer]
#1211917
04/09/12 01:59 AM
04/09/12 01:59 AM
Posts: 276 Bennett, Colorado
Charger69RT8
Bennett, Colorado
On my '92 the distance sensor failed, twice actually. First time at probably low 100's second time around around 200K. Mine is a V8 but the sensor is the same as the V6. Speedometer cable screws into it at the transmission. Same result. Refused to go into OD. According to the wiring diagram in my FSM for it the feed is directly from the ECM. Should be throwing a code 15 if the distance sensor has failed.
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
