Nominal size of RB Main Bore? #1208819
04/03/12 12:01 AM
04/03/12 12:01 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
I just need to know the size of the actual bore of a RB 440 block. I was checking clearances and I came up too large... I did measure the bore with and without the bearing installed...so I would like to check if the block was line honed correctly.
Thanks very much.
Re: Nominal size of RB Main Bore? [Re: Chargerfan68] #1208820
04/03/12 01:18 AM
04/03/12 01:18 AM
Delray beach, Florida
P
Performance Only Offline
P
2.9425-2.9430
machine shop owner and engine builder
Re: Nominal size of RB Main Bore? [Re: Performance Only] #1208821
04/03/12 01:21 AM
04/03/12 01:21 AM
New York, USA
New York, USA
Thank you very much...I'll check that against what I measured tomorrow when I get out to the shop.
