69 Barracuda modification. Rolling
#1208733
04/02/12 11:10 PM
04/02/12 11:10 PM
Posts: 415 Peru
cbarracuda
Peru
Re: 69 Barracuda modification-Pictures
[Re: cbarracuda]
#1208734
04/02/12 11:47 PM
04/02/12 11:47 PM
Posts: 914 tn
robnbird
tn
It was a good running car that did consistent 10.20s in a peruvian track that was not the best, so I decided to loose some weight instead of going for a bigger motor. It was hard to make the first cut but after that it only took a couple of days to remove the old rollbar, the complete floor and the old frame. Here's some pictures so you guys can critique my work
NO DOUBT YOU GOING THE CORRECT WAY, PLUS I KNOW HOW TO DO MY PATIO CONCRETE NOW.
[Re: cbarracuda]
#1208735
04/03/12 12:33 AM
04/03/12 12:33 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
it is nice to work at home keep up the good work
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Palindrome Cuda]
#1208737
04/03/12 11:47 AM
04/03/12 11:47 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
wish i had the balls and money to try building a car like that
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: cbarracuda]
#1208738
04/03/12 12:04 PM
04/03/12 12:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Nice work but I have to ask... why didnt you go with round tube(moly) it would have been a lot lighter than the big rectangular
[Re: cbarracuda]
#1208740
04/06/12 12:17 AM
04/06/12 12:17 AM
Posts: 415 Peru
cbarracuda
Peru
Thank you guys for the feedback. Sixpackgut: you're right, it was hard to start cutting the car. What I did first was remove the engine, transmision, rear end, gages etc. things you can remove with tools. Tried to fool myself by thinking that everything could be bolted back. Then I went to the airport to pick up my parts, after that I finally made the decision to make the first cut,the front right compact so there was no turning back. Now that I started building the car back I'm really happy thinking it's going to be a better race car. Mr.P body: you're right, cromoly tubbing is lighter but you need to stress relieve the welds and there is no oven big enough in Peru, that I know of, to do that. Also i'm using square tubbing frame because it is more generic and easier to build. The car was a 2650 and I'm shooting for a 2200 finish without my 220 pounds. About the 8 3/4, she stays. With the 35 axles, spool and the light weight of the car, she will be ok.
[Re: cbarracuda]
#1208741
04/06/12 02:10 AM
04/06/12 02:10 AM
Posts: 16,542 On the run…
BloFish
On the run…
About the 8 3/4, she stays. With the 35 axles, spool and the light weight of the car, she will be ok. I would say you are safe
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: dartman366]
#1208743
04/06/12 08:08 AM
04/06/12 08:08 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
Nice work, you weld for a living? sure looks like it.
those are great MIG welds...
[Re: dartman366]
#1208744
04/06/12 01:40 PM
04/06/12 01:40 PM
Posts: 415 Peru
cbarracuda
Peru
thanks but I´m not a welder, I´m a engine builder so I hired a welder and so far we have 56 hours working on the frame.
[Re: Dono]
#1208747
04/07/12 06:43 PM
04/07/12 06:43 PM
Posts: 415 Peru
cbarracuda
Peru
I would like to do this to my 67 knotch back. Where did you get the goodies for the four link? Going with a full glass front end too?
Cheers Don.
The 2 rear frame rails and the four link kit are from Competition Engineering . The front rails and the rear cross member 3x2 tubbing is local.
[Re: Dartin]
#1208750
04/09/12 12:54 AM
04/09/12 12:54 AM
Yes that welding does look great, a steady hand forsure.
[Re: cbarracuda]
#1208752
04/17/12 01:51 AM
04/17/12 01:51 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
UHH, You do know the distributor is in the wrong place, right??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
