Scattershield on street driven E Body?
#1208339
04/02/12 04:04 PM
04/02/12 04:04 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
I'm working on a 440, 4 speed swap into my 73 challenger. I don't have a bellhousing yet, and i have a chance to get a lakewood scattershield with the block plate. This is going to be mostly a street driven car, but i want to be able to drive it hard. I'm shooting for 500-550 horsepower. Is it going to be a pain to get it to fit in the e body? will i have ground clearance issues (oklahoma has terrible roads)?
Since the scattersheild doesn't have an inspection cover, is this going to be a pain to inspect, set up a new clutch?
I'd be able to trade for some parts i already have. Total, it will cost me about a third of getting a new bellhousing from brewers.
Part of me is saying why not, its safer. But i'm not sure if it would help me get on the track. The SFI sticker says 2004, and if i had to trim the sides to clear the headers. It wouldn't be any good anyway. Will most tracks let you run 11.99 or faster with a scattershield even if the SFI is out of date, and possibly trimmed?
Re: Scattershield on street driven E Body?
[Re: 5spdcuda]
#1208341
04/02/12 06:48 PM
04/02/12 06:48 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Headers, starter, you name it, it was harder due to the scattersheild.
Buncha whiners !!!
I have a scattershield in my '69 'runner. Sure, its a little more troublesome than a stock bell but what aftermarket part isn't more trouble than stock ?!?!? Go for it. As far as trimming, there are a ton of them out there on race cars that have been trimmed, cut, welded, etc. Do whatcha gotta do! The better quality the headers are the better they'll fit. Do some research - some will specifically say they don't fit with a scattershield. And as far as that inspection cover ... either the clutch works or it don't, you don't need that cover to be able to make adjustments. Make sure you get the right one for your flywheel size !!!
[Re: Sixgun]
#1208343
04/03/12 09:47 AM
04/03/12 09:47 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Betcha those extra hours and dollars wouldn't seem like much if you couldn't drive a manual anymore due to loss of extremities?
Only need it once..
[Re: VoodooCLD]
#1208345
04/04/12 12:01 AM
04/04/12 12:01 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
OK here's the deal. There are two I know of. One, and it seems the most common, is the "Lakewood" "130/143 tooth" combo which never ever seems to have the starter nose cup with it. It has an "extra" row of tabs along the top, and a full ring of bolt holes along the bottom arc for the block saver plate. I refer to it as a combo because in theory you can bolt the starter nose cup in either of two positions, one farther in towards the crank centerline, for the 130 tooth flywheel, one farther out for the 143 tooth. The second flavor is for a 130 tooth flywheel only, no dueling position deals, the starter nose cup is a hole machined into the bell itself, no separatable piece,I have heard these called "Ansen" blowproofs and they have NO block saver plate,nor is their a provision for one. There is a third type I have seen, which is a 2 piece, but I do not think they were or are considered safe enough to contain a clutch or flywheel explosion (think split top half/bottom half with bolt together flanges midway) NOW THEN... The "Lakewood" combo will BARELY fit your e-body, it will be darned near against the floor pan,and you will not be able to lift the motor high enough for removal with the bell and trans left in the car.(DAMHIK).To get the motor in or out by itself you will have to remove the motor mounts and pull it forward level until it's clear of the bell and input shaft. The "Ansen" is a "drop in" but you will have to monkey with your Z bar and linkage to get it right.I am pretty sure any brand 440 blowbell built for the 130 tooth flywheel ONLY will work the same.(69 and earlier "B"s can use the "bigger flywheel" one) I know this stuff for a fact.I am sure there's more someone else can add, as this is all about older stuff that's like swap meet ancient speed parts. Hope this helps, Case
[Re: Sixgun]
#1208346
04/11/12 12:22 AM
04/11/12 12:22 AM
Sixgun
Western Washington
Anyone have anything to add to this? Never even saw a response from the OP? Am I on some weird "ignore" list?
[Re: VoodooCLD]
#1208348
03/26/13 05:01 PM
03/26/13 05:01 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
You better check the run-out and make sure the mounting surface is parallel to the block face before you stuff it in there. I've never heard of one that couldn't use shims and dowels to line it up to the crank centerline correctly.
My 1970 e-body with Lakewood and block saver fits just fine. I installed it with the transmission off and it went right in. No problems. It is a bit tight near the headers and I had to notch it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1208349
03/26/13 06:03 PM
03/26/13 06:03 PM
Posts: 1,973 SoCal
jake4cars
SoCal
I wouldn't run a car like yours without a blowshield. I had a Hay's clutch come apart in my big block 4-speed 69 Camaro a long time ago during a street race on Rt.2 in Conn and was glad for the Lakewood, not only did it sound like a bomb going off it dented the housing from the inside, imagine if that was a factory housing and that Camaro probably only made about 425hp.
As far as fitment goes, how about a quicktime, they look like they would go in there easier, worth investigating at least.
Have fun but be safe, Joey
[Re: jake4cars]
#1208350
03/27/13 07:16 AM
03/27/13 07:16 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
I really REALLY want to sell/swap my Lakewood scattershield and blocksaver for a stock aluminum piece. Reading about fitment/alignment issues, now reading that i cant install engine and trans together with one, the doubled weight over the front end, and yes, the OP's original concerns about maintenance. Basically, i really dont need more hassle to put this car on the road than i already have to deal with, plus... weight-savings is a HUGE aspect ov my build.
Yeah. The choice was obvious.
Then i saw a 65 Impala literally almost get blown in half by a flywheel explosion. Stock wheel, high-RPM burnout (contest), and it started to slip. The explosion tore sizable divots into the pavement, sent large flywheel chunks airbourne, and i'm talking with NO exaggeration, a hundred feet in the air, and over a hundred feet back from the car... almost took out a classic Lotus even... Chunks hit the side ov a motel, many just missed people as the car was surrounded at the time.
As for the car... the hood blew open at the rear, destroyed. The firewall was destroyed. The frame rails were both torn open. The back was torn off the engine (from what i was told). Holes in the floor, a destroyed exhaust, probably a mangled trans and who knows what else.
I had nooooo idea a flywheel could do that to such a stout car. Scary stuff... and now i'm back on the fence about the whole issue...
[Re: Pale_Roader]
#1208351
03/27/13 07:36 AM
03/27/13 07:36 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I had one in a B-body, tti headers, and the only problem I had was I had to make a 1" spacer to put the shift fork in a spot it would work. Some "God" told me I should throw it away because he has a high horsepower car and he doesn't need it, it was junk. But they aren't his feet. It would also be gold if it belonged to him. Oops. Unneded rant. I didn't have any fitment issues, other than the shift fork.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Diplomat440]
#1208353
03/27/13 08:54 AM
03/27/13 08:54 AM
OhioMopar
Mt.Gilead, Ohio
Don Gartlis has. There was a guy I knew that saw a flywheel explode behind a 440 in a '74 Dodge pulling truck.
[Re: Stanton]
#1208355
04/13/13 01:49 PM
04/13/13 01:49 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Thanks for the input guys. I was actually able to drop it in with a spare block mounted to the transmission. I just cut a few slits in the tunnel hump seam and hammered it flat. I have about an inch clearance around the bellhousing now. The torque shaft is still tilted in comparison to the firewall, will this be a problem? I cut an welded the clutch adjuster tab on the torque shaft over 1/2". It now clears the bellhousing when the pedal is sitting on its rubber stop. I'll get some pictures tonight of the angle and you can guys tell me what you think.
[Re: jbc426]
#1208356
04/13/13 01:59 PM
04/13/13 01:59 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Yes i plan to do this, but not until i have my engine built and doing the final mating. Right now i've got a spare bare block bolted to the bellhousing and flywheel so i could easily drop it into the car and align the floor hump, frame bracket, zbar etc..
