Page 4 of 4 1 2 3 4
Re: Well, going to try something different... [Re: StrokerAspen] #1208182
06/01/12 03:14 PM
06/01/12 03:14 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Well, The tranny is coming out today, and getting rebuilt early next week. Since it will be out of the car, why not add a trans brake to the equation? Then back in the car for the weekend to test it all out at a heads up street car event. It's only money right?
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208183
06/01/12 03:20 PM
06/01/12 03:20 PM
Guitar Jones Offline
Yep, it's only money and you can't take it with you so you might as well enjoy what you have. That's my story anyway...
Looks good Kenny I hope it works for you like you wanted.
Re: Well, going to try something different... [Re: Guitar Jones] #1208184
06/01/12 05:03 PM
06/01/12 05:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That car is cool.
Re: Well, going to try something different... [Re: FastmOp] #1208185
06/01/12 09:13 PM
06/01/12 09:13 PM
Alberta Canada
Alberta Canada
Thanks guys, it finally sits the way I like, and I think it has a chance to work well too. While its in the shop again, we went over the front end, and all 4 ball joints need to be replaced, along with both tie rods. Better to find out now, then on the top end on shut down.
-Kenny
Re: Well, going to try something different... [Re: FastmOp] #1208186
06/08/12 03:36 AM
06/08/12 03:36 AM
Alberta Canada
Alberta Canada
The new tranny is in the car now, and I took it for a rip around the block, and everything seems happy. Never had a trans brake before, so that was neat to test out. I bought an MSD 3 step to work with my old 6AL, and a chip pack of 4100-4900rpm. I think that should work. I am starting with the 4100rpm chip to see how things go. If all goes well tomorrow, I should have the first passes on the car around 8. I'll keep ya posted!
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208187
06/08/12 11:09 AM
06/08/12 11:09 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Good-luck and have fun. Those trans brakes can be a lot of fun.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Well, going to try something different... [Re: pittsburghracer] #1208188
06/09/12 03:05 AM
06/09/12 03:05 AM
Alberta Canada
Alberta Canada
I was able to make 3 passes tonight. It seems to work OK so far. I'm sure there is more in it. The air was around 4500ft I believe.
First pass off the trailer. All shocks loose. 4100rpm chip in the two step. 14 psi in the rear tires. 10.89 @ 110mph. 1.55 sixty foot. Tranny was too full and it was smoking bad on the top end as the vent was spewing out onto the exhaust. I lifted and got on the brakes.
Second pass. Proper fluid height. Up the two step up to 4500. 10.72 @ 127. 1.55 sixty.
Third pass. Tightened rear shocks to 9 clicks out of 18. Up the two step to 4900. It hit hard, spun, and did a 10.74 @ 125. 1.57 sixty.
So, as you can see, the sixty foot isn't there yet. It is hooking fairly well so far though. Tomorrow we will see better track prep and temp.
I was able to meet Jason "thedriver" tonight in the staging lanes. Nice to meet a fellow Moparts member up here! There aren't many of us around here!
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208189
06/09/12 03:33 AM
06/09/12 03:33 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: Well, going to try something different... [Re: RemCharger] #1208190
06/09/12 03:57 AM
06/09/12 03:57 AM
Outside
thedriver Offline
thedriver  Offline
Outside
Good seeing you run that super bitchin car Kenny! I'm sure tomorrow will turn out better for you! Once we get the mad wheel hop under control on the sprint 6 chicken we might be running neck and neck!!!! Lol!
I tried to get a pic of your launch but your car was too quick for my iPhone! All I got was a blur!
1973 challenger
Dana. 4 speed. Low deck.
Re: Well, going to try something different... [Re: thedriver] #1208191
06/09/12 10:26 AM
06/09/12 10:26 AM
Alberta Canada
Alberta Canada
Haha thanks Jason. That firebird you guys are running is a sweet machine. Cool to see something a little different!
Today I will try to get some cameras rolling. I have a go pro and my regular camera.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208192
06/10/12 08:48 PM
06/10/12 08:48 PM
Alberta Canada
Alberta Canada
Ended up going 10.56 @ 129 mph yesterday. There is a bit of suspension tuning to do for sure. I need to move my bottom shock mount up for starters in the rear, but I need to trim my shock mounts so they miss the wend on the diff. I'd like to add a rear sway bar to the car as well. If anyone has any suggestions, I am all ears! Here are a couple videos. I am pretty sure the drivers side rear shock is topping out on launch. The shocks I put in only had 3-7/8" of travel. I was guessing where my anti squat line is, and thought it was going to squat, but the diff is coming out of the car. When I bolted the rear shocks on, I left about 2.5-3" of room to compress, so not much left on extension. Next outing I will trim the shock mount and run more extension room.
On the upside, I made it to the final in the 10.00 class (was only 5 of us to start with) and got taken out by my friend Darryl in his 572 440-1 1970 road runner. Our cars run very close motor to motor. So, he put his nitrous tune up in and strayed it out of the hole a little to get me! haha.
http://youtu.be/Rw97ylw9Slk
http://youtu.be/peH6JTg3SU0
http://youtu.be/M_RYaJQ5_KE
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208193
06/10/12 09:37 PM
06/10/12 09:37 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Common misconception that leaf spring cars squat, rather than extend on the hit. Glad you're making some progress, and it's always good to see someone try something different!
Alan Jones
Re: Well, going to try something different... [Re: LA360] #1208194
06/10/12 09:46 PM
06/10/12 09:46 PM
Alberta Canada
Alberta Canada
If I just had leafs, I could see that being the case, but it's really more of a 4 link now. If I move the front of my top bar up a hole, the car will probably squat, as I am pretty sure it would put my instant center under the anti squat line, where ever it is.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208195
06/10/12 11:05 PM
06/10/12 11:05 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
i'm running that susp under my demon and they way it's set-up the top bar on the right side is down 1 hole and the left top bar is straight, and my car goes straight when it leaves.............Nice videos also
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Well, going to try something different... [Re: 67mprfan] #1208196
06/11/12 01:16 PM
06/11/12 01:16 PM
Alberta Canada
Alberta Canada
I might have to try that out! What 60 foots are you seeing? I'd like to get down into the lower 1.4X range
Re: Well, going to try something different... [Re: StrokerAspen] #1208197
06/12/12 03:36 PM
06/12/12 03:36 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
My best 60 ft was a 1.50 with a friend driving,1st year at the track new build wore out slicks i raced this past weekend and average 1.51's still trying to get the bugs out the motor
youtube video...11.31 demon pass... is the link 1st time at the track
Re: Well, going to try something different... [Re: 67mprfan] #1208198
07/18/12 03:27 AM
07/18/12 03:27 AM
Alberta Canada
Alberta Canada
I checked out the video, looks good! Your foot braking it I assume? I have not tried the foot brake yet. I competed in a local event called the 100 foot dash. Basically single runs timed over 100 feet. Here are some pictures...
Spinning a bit on this one...
Different angle of first launch... I need an anti roll bar lol
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208199
07/22/12 11:47 PM
07/22/12 11:47 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Nice pics wish my left with wheels in the air
Page 4 of 4 1 2 3 4
