Re: Well, going to try something different...
[Re: StrokerAspen]
#1208183
06/01/12 03:20 PM
06/01/12 03:20 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Yep, it's only money and you can't take it with you so you might as well enjoy what you have. That's my story anyway... Looks good Kenny I hope it works for you like you wanted.
[Re: RemCharger]
#1208190
06/09/12 03:57 AM
06/09/12 03:57 AM
Posts: 1,481 Outside
thedriver
Outside
Good seeing you run that super bitchin car Kenny! I'm sure tomorrow will turn out better for you! Once we get the mad wheel hop under control on the sprint 6 chicken we might be running neck and neck!!!! Lol! I tried to get a pic of your launch but your car was too quick for my iPhone! All I got was a blur!
1973 challenger Dana. 4 speed. Low deck.
[Re: StrokerAspen]
#1208192
06/10/12 08:48 PM
06/10/12 08:48 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Ended up going 10.56 @ 129 mph yesterday. There is a bit of suspension tuning to do for sure. I need to move my bottom shock mount up for starters in the rear, but I need to trim my shock mounts so they miss the wend on the diff. I'd like to add a rear sway bar to the car as well. If anyone has any suggestions, I am all ears! Here are a couple videos. I am pretty sure the drivers side rear shock is topping out on launch. The shocks I put in only had 3-7/8" of travel. I was guessing where my anti squat line is, and thought it was going to squat, but the diff is coming out of the car. When I bolted the rear shocks on, I left about 2.5-3" of room to compress, so not much left on extension. Next outing I will trim the shock mount and run more extension room. On the upside, I made it to the final in the 10.00 class (was only 5 of us to start with) and got taken out by my friend Darryl in his 572 440-1 1970 road runner. Our cars run very close motor to motor. So, he put his nitrous tune up in and strayed it out of the hole a little to get me! haha. http://youtu.be/Rw97ylw9Slkhttp://youtu.be/peH6JTg3SU0http://youtu.be/M_RYaJQ5_KE-Kenny
[Re: StrokerAspen]
#1208193
06/10/12 09:37 PM
06/10/12 09:37 PM
Posts: 6,149 Melbourne , Australia
LA360
Common misconception that leaf spring cars squat, rather than extend on the hit. Glad you're making some progress, and it's always good to see someone try something different!
Alan Jones
[Re: StrokerAspen]
#1208195
06/10/12 11:05 PM
06/10/12 11:05 PM
Posts: 1,030 ohio
67mprfan
ohio
i'm running that susp under my demon and they way it's set-up the top bar on the right side is down 1 hole and the left top bar is straight, and my car goes straight when it leaves.............Nice videos also
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: StrokerAspen]
#1208197
06/12/12 03:36 PM
06/12/12 03:36 PM
Posts: 1,030 ohio
67mprfan
ohio
I might have to try that out! What 60 foots are you seeing? I'd like to get down into the lower 1.4X range
My best 60 ft was a 1.50 with a friend driving,1st year at the track new build wore out slicks i raced this past weekend and average 1.51's still trying to get the bugs out the motor
youtube video...11.31 demon pass... is the link 1st time at the track
[Re: 67mprfan]
#1208198
07/18/12 03:27 AM
07/18/12 03:27 AM
StrokerAspen
Alberta Canada
I checked out the video, looks good! Your foot braking it I assume? I have not tried the foot brake yet. I competed in a local event called the 100 foot dash. Basically single runs timed over 100 feet. Here are some pictures... Spinning a bit on this one... Different angle of first launch... I need an anti roll bar lol -Kenny
[Re: StrokerAspen]
#1208199
07/22/12 11:47 PM
07/22/12 11:47 PM
Posts: 1,030 ohio
67mprfan
ohio
Nice pics wish my left with wheels in the air
