Page 2 of 4 1 2 3 4
Re: Well, going to try something different... [Re: don miller] #1208142
04/03/12 03:31 PM
04/03/12 03:31 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
There were two inherent "problems" with the original leaf link.
First clamping the spring solid to the pivot created a bind, you could ease that by having the spring slide in the pivot. Second issue was even with ss prings it would kill the spring at the front eye very quickly. Calvert addresses this with their monos being much thicker than even the old made in Canada ss springs. Despite these correctable shortcomings they did work but were shelved when Jenkins tilted the playing field when he debuted his Vega
I don't think this is why Calvert has done a thick mono leaf. If you put a true leaf spring car on a four corner scale, then drive it around the block, and put it back on the scales, your readings will be different. Leafs bind on each other. The mono leaf is a more constant spring. When the Caltracs are under load, those monos are in tension. In the leaf link, the leaf is unfortunately in compression.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208143
04/04/12 02:39 AM
04/04/12 02:39 AM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
Kenny you might try contacting StewartP-he was in with Don Carlton, the Missile boys etc back when this was "new" he could probably give you better advise than us.
Re: Well, going to try something different... [Re: don miller] #1208144
04/04/12 11:12 AM
04/04/12 11:12 AM
Alberta Canada
Alberta Canada
Good to know Don. I will hunt him down for some info! Just made a deal on a new engine for the tow rig, maybe I will make it out your way to some races this summer now!
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208145
04/04/12 12:21 PM
04/04/12 12:21 PM
SoCal
Brian Hafliger Offline
SoCal
Hey Kenny, I tried returning your dads phone call but I think I'm missing a digit...I tried PM'n you but your box is full.
Brian
Brian Hafliger
Re: Well, going to try something different... [Re: Brian Hafliger] #1208146
04/04/12 12:48 PM
04/04/12 12:48 PM
Alberta Canada
Alberta Canada
Brian
Oops! Going to have to clean it out!
Here is the shop info...
www.josstechnical.com
403-320-7272
Thanks.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208147
04/06/12 01:46 AM
04/06/12 01:46 AM
Alberta Canada
Alberta Canada
Cut the brackets on the water jet today at work, starting to connect the dots now.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208148
04/06/12 07:11 AM
04/06/12 07:11 AM
MI
68shifter Offline
68shifter  Offline
MI
Looks good man! Good to see a different setup being tried. I'd like to see how the results turn out all said and done. Good luck.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Well, going to try something different... [Re: StrokerAspen] #1208149
04/06/12 01:52 PM
04/06/12 01:52 PM
Alberta
rustbuckett68 Offline
Alberta
These them?
Re: Well, going to try something different... [Re: rustbuckett68] #1208150
04/06/12 01:53 PM
04/06/12 01:53 PM
Alberta
Alberta
#2
Re: Well, going to try something different... [Re: rustbuckett68] #1208151
04/06/12 01:58 PM
04/06/12 01:58 PM
Alberta
Alberta
#3
Re: Well, going to try something different... [Re: rustbuckett68] #1208152
04/06/12 02:54 PM
04/06/12 02:54 PM
Guitar Jones Online laugh2
So basically the leaf spring becomes the lower bar of a four link. That is going to be in compression then as stated earlier. I can see where that would cause a lot of stress on the spring.
Re: Well, going to try something different... [Re: Guitar Jones] #1208153
04/06/12 05:33 PM
04/06/12 05:33 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
Exactly, that is why DC recommended S/S springs and also to clamp the front segment extensively. It will still kill the spring close to the front eye quite quickly.
Re: Well, going to try something different... [Re: rustbuckett68] #1208154
04/06/12 07:30 PM
04/06/12 07:30 PM
Alberta Canada
Alberta Canada
Yup, those are the diagrams! Here are some updated pictures. Things that are still left to do are the top bars, shock mounting kit, and lastly will be brake lines. Then we will move on to retro fitting a QA1 A Body front shock into this goofy FJM front suspension.
My Leaf mount...
Fitting in the car...
Dropped down on the ground...
Up on jack stands. Starting to sort out the top bar.
One step at a time!
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208155
04/06/12 07:55 PM
04/06/12 07:55 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice fab work and welds. The only issue I can see is with the front of the spring and top bar having different radius there will be some rocking of the rear when the suspension moves. I would be worried about that rocking motion loosening up the bolt that ties the spring perch.
Re: Well, going to try something different... [Re: Bigcube] #1208156
04/06/12 08:39 PM
04/06/12 08:39 PM
Alberta Canada
Alberta Canada
Thanks Bigcube, I can't take credit for the welding and fab skills, that would be a couple of my buddies with the welding skills, one owns the green demon in the back ground of some pictures.
The bolt your referring too is my lower mount correct? That will have a lock nut on it. None of the GM G bodies or fox body mustangs have equal length top and bottom bars. Is it a compromise for what I'm doing? For sure! But I think it can still be made to work.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208157
04/09/12 03:50 PM
04/09/12 03:50 PM
Alberta Canada
Alberta Canada
I think I came up with an idea for saving the front spring segment! Stay tuned, should be finishing things off in the next week or two!
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208158
04/12/12 12:31 PM
04/12/12 12:31 PM
Alberta Canada
Alberta Canada
I was able to get some more measurements off the car for the final rear pieces to get cut and bent up. I had a chromoly cross member bent up to mount off of for the top links to hook to. After measure up on the rear end of the car we started hacking and chopping the front of car up to fit the front QA1's. The stock shocks in an FJM Body are too short for shock companies to build a truely adjustable front shock. There isn't enough room to put the valving in the shock body. I will have to get some pictures next time I'm out there.
ThIngs are getting tight in the back end haha! It should look about right though in my opinion when it's sitting on the ground.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208159
04/22/12 05:57 PM
04/22/12 05:57 PM
Alberta Canada
Alberta Canada
Alright, we were able to spend a little more time on the rear suspension yesterday. We built the upper shock mount cross member and got everything tacked in place.
-Kenny
Re: Well, going to try something different... [Re: StrokerAspen] #1208160
04/22/12 07:17 PM
04/22/12 07:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
First: more power to you, and anyone else who tries to improvise.
My knowledge of suspension tuning is very slight. What I can offer is a prediction of how sanctioning bodies deal with innovation.
1. if you mail them a diagram and explanation and ask for a ruling, they will not give you legal status in writing
2. personal and phone conversations never took place, didn't go the way you said etc.
3. the tech line is only concerned with safety rules - not legality
4. being permitted to race doesn't mean that they agree that you're legal
5. nothing will happen until you beat someone important/influential - you know, the guys married to Force's cousin, blah
6. when protested you fail
The reason given may take various forms as to language, beginning by simply stating the "it's not in the rules" (actual non-compliance). Your objection that it's not prohibited will be met with "it violates the spirit of the rule" (translation: we don't like you).
The underlying reason is simple: you beat someone more important than you.
IMHO it's not legal, in that you're not using the suspension in a different way. It would fail an objection based on patentable engineering features (not enough commonality with OEM).
There are 2 main points of difference:
1. the original leaf was both the entire suspension and the locator for the axle, now it's not
2. a new part has assumed some of the original function, which is not stock
Boffin Emeritus
Re: Well, going to try something different... [Re: polyspheric] #1208161
04/22/12 07:52 PM
04/22/12 07:52 PM
gregsdart Offline
gregsdart  Offline
I am betting it will work great if two areas are addressed? Strength of the front half of the lower leaf. Stiffening it with another leaf that goes all the way to the spring eye may do the trick, but never tried it. The other thing on my mind is freedom of spring rate. If the shackles are too short or at the wrong angles, things get goofy. I am betting if these items are addressed, along with instant center being adjustable it should work like a four link.
Page 2 of 4 1 2 3 4
