340 six pack idle stop solenoid #1207608
04/01/12 04:58 PM
04/01/12 04:58 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Can anyone tell me where I can get a 1970 340 six pack idle stop solenoid rebuilt? Worse case, where can I buy one?
Thanks in advance
Re: 340 six pack idle stop solenoid [Re: sailboat] #1207609
04/01/12 07:06 PM
04/01/12 07:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yours should be a DR1114429 (stamped into the outer casing). Unfortunately these are rare and expensive even as used parts ($400-500.00 on average). I have one here on the shelf owned by a customer who wants me to sell it for him, if you can't find one, it's top dollar.
If yours is an original and still functions and you want it restored I can do that for you. If it does not function and you want it restored I can also help you but it gets more complicated. You would need to provide me with another good working unit that I can swap out the internals from into your outer casing. Any solenoid with the same shape outer casing will work, different part# is ok, used or NOS is ok, as long as it still functions. The reproductions on the market have weaker internals and are not reccomended as parts donors or anything else.
Re: 340 six pack idle stop solenoid [Re: ScottSmith_Harms] #1207610
04/02/12 02:16 AM
04/02/12 02:16 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Tonys had one listed for $300 a while back. better grab it if he still has it. it took me 2 years to find one for my lowly 71 340 4 hole.
Re: 340 six pack idle stop solenoid [Re: ScottSmith_Harms] #1207611
04/02/12 11:02 AM
04/02/12 11:02 AM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
I agree with Scott, I bought a repro and am on the third unit as the coil seems to be very weak.
B5 Challenger T/A
Re: 340 six pack idle stop solenoid [Re: KARLN] #1207612
04/02/12 06:19 PM
04/02/12 06:19 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Is that blue TA yours? Are you in Mississauga? Im loctaed in Guelph.
