looking for 716 bolts with washers #1207421
04/01/12 01:17 PM
04/01/12 01:17 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
on this 68 plymouth the bolts have the washers installed, then i believe the threads are put on afterwards.
these bolts are located under the rear bumper panel and hold the rear bumper bracket to that panel.
over the years from dirt, moisture and rust build up, the washers on the bolts would break in half.
where can i find more of these bolts w/ washers?
Re: looking for 716 bolts with washers [Re: 4spdana] #1207422
04/01/12 02:23 PM
04/01/12 02:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
something like this ?
[image]http://amkproducts.com/bulk3.asp?part=B%2D13717[/image]
Re: looking for 716 bolts with washers [Re: gtx6970] #1207423
04/01/12 03:16 PM
04/01/12 03:16 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
hey , thanks....what are bolts called that have a washer on first then the threads put on?
Re: looking for 716 bolts with washers [Re: 4spdana] #1207424
04/01/12 06:27 PM
04/01/12 06:27 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It's called a captured washer. Can be on a bolt or nut.
Re: looking for 716 bolts with washers [Re: B5 Bee] #1207425
04/01/12 09:27 PM
04/01/12 09:27 PM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
Alo called SEMS bolts. Shortened from pre-asSEMbled.
Re: looking for 716 bolts with washers [Re: MattMPA] #1207426
04/01/12 09:55 PM
04/01/12 09:55 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
hey... thanks.... GearHead for Life
