2005 DODGE, BOTH KEY fobs are not working? #1207123
03/31/12 06:38 PM
03/31/12 06:38 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
one stopped 2-3 yrs ago, 2nd stooped today. tried new batteries. what needs to be done to get new ones.
Re: 2005 DODGE, BOTH KEY fobs are not working? [Re: 05dakota] #1207124
03/31/12 06:59 PM
03/31/12 06:59 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Use the key. That's what I do. Not spending $60 (or whatever it is now) for a new fob, and $60 for dealer programming.
Turn the key once to lock that door, twice in the same direction to lock all doors - at least that's how it works on the Durango.
Re: 2005 DODGE, BOTH KEY fobs are not working? [Re: MoparMarq] #1207125
03/31/12 07:13 PM
03/31/12 07:13 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
you any good w/ a soldering iron & printed circuit boards? it might be something you can fix easily, on one of mine, the soldered contact joints of the clip that holds the battery broke free from the board causing a non functioning situation. i carefully disassembled the fob & re-soldered it, & it has been working for at least a yr now. this in on a '06 magnum though, dakotas might be totally different.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: 2005 DODGE, BOTH KEY fobs are not working? [Re: 05dakota] #1207126
03/31/12 09:06 PM
03/31/12 09:06 PM
places
79powerwagon Offline
places
eBay. I always buy fobs off of there, about $15.00 each delivered.
