Re: What if a coil was hooked up backwards
[Re: Cab_Burge]
#1206505
03/30/12 03:54 PM
03/30/12 03:54 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
Can't tell you how many times over the years I have seen them hooked up backwards. They run fine, but don't make max spark. I switch them to the correct positions and don't notice any difference. I assume that it does some damage to the coil from running it backwards, but don't really know for sure. I always put a Jacobs coil on everything eventually anyway.
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: DconD100]
#1206506
03/30/12 04:11 PM
03/30/12 04:11 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I saw some backwards also.On the scope the pattern is reversed.Our scope also showed max output voltage.It pretty much showed the same as when hooked up correct.Kind of freaks you when you see the patterns upside down the first time.Never saw one that didnt run when it was wrong.Rocky
Chrysler Firepower
[Re: therocks]
#1206507
03/30/12 04:23 PM
03/30/12 04:23 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
These replies are correct, it still works but shows an upside down pattern on the scope, if you still have one of those stone age machines. Any way the more important question is do electrons flow from positive to negative or is it really the reverse? There are a lot of thoughts on this but yet all the positive ground cars were electrical pieses of poo, but that could have just been because Lucas did the electrical on them. lol It's like the old joke, Do you know why the British drink their beer warm? Because Lucas makes their refrigerators. You old timers will get it, you young guns may not.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1206508
03/30/12 04:45 PM
03/30/12 04:45 PM
Posts: 5,080 organ
maximum entropy
organ
i DO have an old 'scope. a big one. too bad it's a marquette, and not a sun. and about the lucas electronics, we never could keep the smoke inside. it always got out, eventually.
[Re: BradH]
#1206511
03/30/12 06:15 PM
03/30/12 06:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It will reduce the life of the coil... the 2 different windings also have different size wires and the thin wires dont last all that long
[Re: B G Racing]
#1206514
03/30/12 09:16 PM
03/30/12 09:16 PM
Posts: 550 Camp Point, IL
gofish
Camp Point, IL
It depends a lot on what the system is built like. Old points ignition systems had a capacitor that charged up as the points were open and when the points closed the capacitor (called condenser in those days) discharged through the coil, pulsing the coil primary inducing the current into the coil secondary causing the high voltage spark. If the points and capacitor w ere on the ground side of the coil, the inductance and resistance of the primary winding could be enough to keep the capacitor from charging up as high as if it were on the positive side of the coil. I have not looked at newer systems enough to guess if the same principle applies or not, but a coil is not a polarized device by itself, but supporting parts may be. A car coil is actually a transformer, two separate windings, primary (low voltage in this case) and secondary (high voltage in this case). The transformer can be wired as a step up or step down, depending on the need. If you tried to apply the low voltage into the high voltage secondary, then you would get very low voltage out of the coil primary and not have enough voltage to ever jump the gap on a plug. An older ignition system would have about 20,000 volts out of the coil secondary and if you pulsed the 12 VDC to the high voltage side of the coil, the output on the low voltage side would be very low, in the .0075 VDC range.
Danny
[Re: Guitar Jones]
#1206516
03/30/12 11:55 PM
03/30/12 11:55 PM
Posts: 7,506 Az
Crizila
Az
TOOOOO FUNNY!!! Yes, the scope pattern is backwords, and the open voltage ( available voltage ) will be less - along with a shorter firing line. And yes, it will hurt a coil in pretty short order. And yes, as said, if it's a Lucas ignition, it won't make any difference cause it won't work ether way.
Fastest 300
[Re: 383man]
#1206517
03/31/12 12:05 AM
03/31/12 12:05 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Yep it gives a weaker spark. Dont you guys remember the old pencil trick in the older Motor Manuals to tell if the coil polarity is wrong ? Ron
Ron,you are really showing your age here!
But,yes,I remember it too. I have one of those manuals around here somewhere still. Keith
[Re: 383man]
#1206518
03/31/12 12:26 AM
03/31/12 12:26 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I remember it Ron! You beat me to it And , No, Im not old like Ron
Im 29
[Re: Sport440]
#1206519
03/31/12 08:17 AM
03/31/12 08:17 AM
therocks
Niles , Ohio
Lucas the Prince of Darkness.I had a buddy that had a Triumph 650.I think every week we worked on the electrics.Guy I went to school with has a Triumph 650 now.Its the only one Ive seen that the electrics work on.Rocky
Chrysler Firepower
[Re: B G Racing]
#1206521
03/31/12 10:26 PM
03/31/12 10:26 PM
Posts: 19 N.E. IL. U.S.A.
Rumblefish68
N.E. IL. U.S.A.
Bought a used 69 Dodge in 1976 with a big block and totally stock, points style ignition. Car would start fine and ran fine until the temperature got down to about freezing, then it would not start if left to get down to ambient air temp. If put in the garage to warm up, it would start with the starter motor, otherwise you had to push it to start. (4-sd.) After dealing with this for 2-3 months, started looking at everything and decided to replace the coil thinking it was "weak". Found the previous owner had a kill switch wired to the coil and the leads were re-installed on the coil backwards. Switched them back and everything was fine. By the way,it only had 8,300 miles on it, I still have it ,it has 27,000 on it now, and the original coil is still in it. Most puzzling thing I ever saw. The original owner never had a problem because He only drove it on nice summer days. I knew the car since new, bought it from my cousin, the original owner. Jay
