intake manifold vac. #1206236
03/29/12 10:09 PM
03/29/12 10:09 PM
dark side of the moon
Dougsmopars Offline OP
Got my new 750 Quick carb. In the booklet it says for power brakes use vac at rear of carb not one in an intake runner like the stock intake. Is there a difference in vac between the two positions?
Re: intake manifold vac. [Re: Dougsmopars] #1206237
03/30/12 12:21 AM
03/30/12 12:21 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
do you have a vac gauge? if so check at both locations. remember power brakes means that you do not to push as hard on the pedal. most stock motors will pull about 14in of vac, enough for brakes and other stuff. you have to wonder why your carb would spec out a vac source, i believe stock would have from the manifold. unless the carb has a vac pump on it, why would it produce more vac than the intake manifold?
Re: intake manifold vac. [Re: Dougsmopars] #1206238
03/30/12 02:37 AM
03/30/12 02:37 AM
Is your intake a dual plane or single plane? If single it won't matter which port you use, if dual plane Quikfuel may be thinking that using the stock location may limit the vacume to 1/4 of the total engine vacume, I wouldn't bet on that
Re: intake manifold vac. [Re: Cab_Burge] #1206239
03/30/12 03:10 AM
03/30/12 03:10 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
The other question is where do you put the PCV, it doesn't leave a lot of choices apart from sucking all the engine fumes into one cylinder....not the ideal scenario!
Re: intake manifold vac. [Re: Cab_Burge] #1206240
03/30/12 05:43 PM
03/30/12 05:43 PM
Stock dual plane cast iron intake.
