Aftermarket stereo for E-body...... #1205907
03/29/12 05:24 PM
03/29/12 05:24 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
For those that have installed one did you use some kind of bracket to install it or did the standard stereo basket fit the space okay?
Re: Aftermarket stereo for E-body...... [Re: dustergirl340] #1205908
03/29/12 06:27 PM
03/29/12 06:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Had to make custom bracket..
Re: Aftermarket stereo for E-body...... [Re: Challenger 1] #1205909
03/29/12 06:30 PM
03/29/12 06:30 PM
BDW Offline
BDW  Offline
I was able to use the standard basket, it attached to the plastic perfectly.
Re: Aftermarket stereo for E-body...... [Re: BDW] #1205910
03/29/12 07:48 PM
03/29/12 07:48 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Okay...thanks guys. Haven't got the stereo yet, just wanted to see what others have done.
Re: Aftermarket stereo for E-body...... [Re: dustergirl340] #1205911
03/29/12 08:50 PM
03/29/12 08:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
It'll fit the dash opening...Add a stud on the back of the new unit and fasten it to the dash frame..{Just like they were originally}...You may need to use a universal metal strip instead of the factory piece between the new unit and the dash frame...
Re: Aftermarket stereo for E-body...... [Re: screamindriver] #1205912
03/29/12 09:15 PM
03/29/12 09:15 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Great...thanks for the info!
Re: Aftermarket stereo for E-body...... [Re: screamindriver] #1205913
03/30/12 11:36 AM
03/30/12 11:36 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
.................BUT you may have to trim around the plastic lower dash frame on most E-Bodys to get the aftermkt radio face trim to fit. I usually have to sand back the corner about 1/8 to 3/16 with a dremel to get the face to fit.
Re: Aftermarket stereo for E-body...... [Re: THESHAKERPROJECT] #1205914
03/30/12 11:41 AM
03/30/12 11:41 AM
BDW Offline
BDW  Offline
True, it's been so long I forgot about that.
Make sure you look for a radio with a super thin bezel if possible.
Re: Aftermarket stereo for E-body...... [Re: BDW] #1205915
03/30/12 01:38 PM
03/30/12 01:38 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
I'll do that...thanks again guys!
Re: Aftermarket stereo for E-body...... [Re: dustergirl340] #1205916
03/31/12 12:26 AM
03/31/12 12:26 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I put mine in without the outer bezel, now that most radios are flat faced and then you do not have to modify the lower dash plastic bezel
