Best Stock appearing spark plug wire set? #1205709
03/29/12 01:19 PM
03/29/12 01:19 PM
Kent, WA
triple_green Offline OP
Kent, WA
I don't need high dollar repros down to the part number.
What is available that is stock appearing and good quality?
68 383 HP all stock except for the petronix ignition kit.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Best Stock appearing spark plug wire set? [Re: triple_green] #1205710
03/29/12 02:06 PM
03/29/12 02:06 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I have 2 sets of them. One is a Taylor 7MM set and one is a MOPAR OEM replacement. Both for a 383. PM me if interested....
Re: Best Stock appearing spark plug wire set? [Re: CR8CRSHR] #1205711
03/29/12 02:50 PM
03/29/12 02:50 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Rick from Firecore is a sponsor on here, he's had numerous positive testimonies on here about his stock appearing wire sets - I'm about to buy some for my 440.
I think his user name is sunroofgtx??
Good guy that stands behind his product.
Re: Best Stock appearing spark plug wire set? [Re: triple_green] #1205712
03/29/12 03:21 PM
03/29/12 03:21 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Firecore gets rave reviews around here. I don't have a set but my next set will be Firecore. SunroofGTX makes them.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Best Stock appearing spark plug wire set? [Re: bigsbigelow] #1205713
03/29/12 04:32 PM
03/29/12 04:32 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
There's also the Accel "300" wire set, IIRC; black wire, orange plug boots, work fine on my 440. You can remove the Accel lettering with lacquer thinner or wax & grease remover.
Re: Best Stock appearing spark plug wire set? [Re: wkroncke17] #1205714
03/30/12 11:10 PM
03/30/12 11:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yes Rick makes an OEM looking set with the good conductors that he uses in the Firecore50 race wires but fit with manifolds in stock wire tabs.They look original but perform like the best race wires
Gus
64 Plymouth Savoy
Dana 60
Re: Best Stock appearing spark plug wire set? [Re: wkroncke17] #1205715
03/30/12 11:31 PM
03/30/12 11:31 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I have two sets from Mr Rick and his Firecore products...Thumbs up..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
