904 early up shift #1205012
03/28/12 09:31 AM
03/28/12 09:31 AM
NY
moparmatt0 Offline OP
NY
Just rebuild a push button 904 and installed a trans go shift kit part number Tf-1 and it shifts good but a little early adjusted the throttle pressure so that the carb is hitting the throttle pressure linkage right off idle but it is still a little early dose any body have any ideas.
Re: 904 early up shift [Re: moparmatt0] #1205013
03/28/12 10:54 AM
03/28/12 10:54 AM
lengthen the linkage a bit
