FRONT SUSPENSION BUSHINGS / MINIVANS #1204429
03/27/12 12:43 PM
03/27/12 12:43 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I've read on here that most of you w/1996-2000 Caravan/Voyagers having to replace bushings in the front suspension.
Is there a kit to be had for does one have to buy them individually?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: FRONT SUSPENSION BUSHINGS / MINIVANS [Re: Magnumguy] #1204430
03/27/12 01:12 PM
03/27/12 01:12 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Which bushings????
Re: FRONT SUSPENSION BUSHINGS / MINIVANS [Re: Magnumguy] #1204431
03/27/12 02:34 PM
03/27/12 02:34 PM
Western NY
19SuperBee70 Offline
Western NY
My sway bar ends went twice, easy to replace. the sway bar bushings themselves also go but mine were OK.
Re: FRONT SUSPENSION BUSHINGS / MINIVANS [Re: 19SuperBee70] #1204432
03/28/12 02:57 PM
03/28/12 02:57 PM
S.E.Ohio
S.E.Ohio
Re: FRONT SUSPENSION BUSHINGS / MINIVANS [Re: Magnumguy] #1204433
03/28/12 03:11 PM
03/28/12 03:11 PM
IMGTX Offline
IMGTX  Offline
I am not sure which bushings but you may consider an upgrade to poly.
Many of the earlier minivans used the same suspension as the Daytona/Shadow/Spirit/Acclaim/etc. They are available in sets (all 4 lower bushings in one kit)
Maybe an option.
Re: FRONT SUSPENSION BUSHINGS / MINIVANS [Re: IMGTX] #1204434
03/28/12 06:08 PM
03/28/12 06:08 PM
KS
68SportSatvert Offline
KS
The sway bar end links and sway bar bushings are notorious for failure. I believe he's talking the sway bar bushings. I agree with above, you need to go with poly. Go to Rock Auto. They have the best prices and parts. I'm in the process of ordering the same parts for my 2002 Grand Caravan.
