68 ralley dash speedo #1204267
03/26/12 11:16 PM
03/26/12 11:16 PM
dark side of the moon
Dougsmopars Offline OP
My speedo works but it doen't move the odometer. I haven't taken the cluster out yet. Anything simple it could be or should i just get another speedo?
Re: 68 ralley dash speedo [Re: Dougsmopars] #1204268
03/29/12 10:28 PM
03/29/12 10:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pull the cluster, get the whole thing restored. If you have problems with the speedo, other gauges may be having problems. Tim
Re: 68 ralley dash speedo [Re: astjp2] #1204269
03/29/12 10:34 PM
03/29/12 10:34 PM
Speedo it self works fine. All the other gauges work fine. Problem is odometer is not moveing.
Re: 68 ralley dash speedo [Re: Dougsmopars] #1204270
03/29/12 11:23 PM
03/29/12 11:23 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There is a small gear that transfers movement from the cable to the odometer section... I've seen that gear pop loose from it's mount.. Take it apart & have a look..
Re: 68 ralley dash speedo [Re: 1_WILD_RT] #1204271
03/29/12 11:41 PM
03/29/12 11:41 PM
Thanks. Thats a start. Maybe get lucky and easy fix.
