Re: Oil pumps
[Re: jamesc]
#1204075
03/26/12 09:14 PM
03/26/12 09:14 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Tell me you are not thinking of installing a HV pump as a band-aid for your low oil pressure? I would be investigating the cause before something goes terribly wrong. I've never had a big block mopar with less than 40 psi oil pressure at hot idle. Especially with a fresh rebuild.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
