axle sizes 741 and 742 cases #1202591
03/24/12 05:11 PM
03/24/12 05:11 PM
Annapolis, Missouri USA
CIB Offline OP
CIB  Offline OP
i traded for a racecar and I'm trying to make it streetable. It has a 8 3/4 rearend with a 742 case spool and 5:13 gears. I went to swap a 741 case with 3:91 posi and the axles from the 742 were too big to fit the 741 case. I thought they were all the same. Any thoughts?
Re: axle sizes 741 and 742 cases [Re: CIB] #1202592
03/24/12 05:55 PM
03/24/12 05:55 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
evidently the spiders have been changed fron the factory 30 spline to 35 spline.
I am truckless..
Re: axle sizes 741 and 742 cases [Re: CIB] #1202593
03/24/12 11:54 PM
03/24/12 11:54 PM
The racer bought a 35 spline spool and axes for his 8 3/4 You need a set of stock or street axles now to use with the posi
Re: axle sizes 741 and 742 cases [Re: Cab_Burge] #1202594
03/25/12 09:25 AM
03/25/12 09:25 AM
CIB Offline OP
CIB  Offline OP
Thanks for the replys.
Re: axle sizes 741 and 742 cases [Re: CIB] #1202595
03/25/12 09:18 PM
03/25/12 09:18 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Ihave a set of B-body stock 8 3/4 axle shafts....you pay shipping and they are yours
