Holley Street Avenger carbs #1202584
03/24/12 05:01 PM
03/24/12 05:01 PM
dark side of the moon
Dougsmopars Offline OP
Any feedback on the Holley Street Avenger carbs? Anybody running one on a Mild 440 ? Looking at the 770CFM for my 4 speed car. Any coments on these carbs or any better choise? Street car only.
Re: Holley Street Avenger carbs [Re: Dougsmopars] #1202585
03/24/12 05:55 PM
03/24/12 05:55 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
I just put one on my car mild 440 and so far it is way better than the edelbrock that was on it.My dad has one on his car 500 inch stroker and it has been great.
Re: Holley Street Avenger carbs [Re: CARMAN] #1202586
03/24/12 06:57 PM
03/24/12 06:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a 670cfm Truck Avenger on my '70 W100 and it is a nice carb. A bit lean out of the box, but still a good working carb.
On my mild 440 I used a 750cfm Quick Fuel Slayer which is a vacuum secondary carb with all of the tricks (replaceable air bleeds, externally adjustable vac. dashpot, glass bowl sights, etc.) and it has worked great all winter long.
The QF Slayer is $300 compared to the $360-400 for the Holley that has less features.
Re: Holley Street Avenger carbs [Re: Jeremiah] #1202587
03/24/12 07:54 PM
03/24/12 07:54 PM
I'll have to check those out.
Re: Holley Street Avenger carbs [Re: Dougsmopars] #1202588
03/24/12 08:29 PM
03/24/12 08:29 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I have a 770 on the 340 in my Dart. It runs great!
Re: Holley Street Avenger carbs [Re: 6PAX] #1202589
03/24/12 09:41 PM
03/24/12 09:41 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I had a 770 on the tired 440 in my Plymouth. It was pretty lean out of the box. It was a stock 350 horse engine with headers. I was up three jet sizes at all four corners and it was pretty close on the jetting. I can't give a really honest opinion because between the engine being tired and the tranny not holding at WOT, the car never impressed me. It most likely wasn't the carb's fault but expect to fiddle with it!
Re: Holley Street Avenger carbs [Re: GTX MATT] #1202590
03/25/12 07:26 AM
03/25/12 07:26 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
A friend ov mine got sold a 670 version for his stock 440 (76 engine in a 73 Satellite). It was bone stock except for a open element filter and a recurve. It ran great out ov the box, needed very little tuning/tweaking (i think i played with the jetting and the secondary springs), but it was definitely too small for even a stock 440. Great throttle response and got considerably better mpg than my own stock-ish 440 with a 750 vac secondary. I still have it... keeping it around in case i even have a small block in need ov a good carb.
