Alternator question? #1202560
03/24/12 03:29 PM
03/24/12 03:29 PM
illinois
bigblk66_coronet Offline OP
illinois
I got a new Power master alt for my birthday. Well the one i have been running is a single field unit. The new one is a dual field unit. I says you can use it but to run a jumper wire from one field connection to a ground stud on the alternator. There is one little stud and nut on it that goes to nothing......is that the one youre supposed to ground it to? .Joe
Re: Alternator question? [Re: bigblk66_coronet] #1202561
03/24/12 03:34 PM
03/24/12 03:34 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the stud is attached directly to the alternator housing it can be used as a ground.
- Stu Harmon
Re: Alternator question? [Re: bigblk66_coronet] #1202562
03/24/12 03:34 PM
03/24/12 03:34 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Here is the jumper I put on my Powermaster alternator.
Scott
1969 Super Bee, 383/4 speed
Re: Alternator question? [Re: feets] #1202563
03/24/12 03:55 PM
03/24/12 03:55 PM
illinois
illinois
ok i got it guys. Just wanted to make sure so i domnt burn it up. Pretty much everything that could go wrong has gone wrong puttimng this back together
