A couple driveshaft questions #1202545
03/24/12 02:02 PM
03/24/12 02:02 PM
southern Idaho
moparcyco Offline OP
southern Idaho
1.Could someone post the factory drive shaft length for a 70 challenger with a 440 4-speed combo?Also is this measurement taken end to end?Or from center to center on the u-joints?
2.Is it possible to feel a drive shaft vibration in your steering wheel?I have a slight vibration I checked everything in the front end its all tight had all four wheels balanced cant figure out where its coming from.I changed a u-joint last weekend and could push the caps in with my fingers so I know the shaft needs replaced.As always thanks guys
Re: A couple driveshaft questions [Re: moparcyco] #1202546
03/24/12 03:54 PM
03/24/12 03:54 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
From 70' manual - 440 / 4-speed / should have a Dana 60 as well.
44.60 inches measurement is from center line of bearing bore to centerline of brg bore.
Shaft diameter is 3.25 inches
Re: A couple driveshaft questions [Re: pacifica] #1202547
03/24/12 07:20 PM
03/24/12 07:20 PM
southern Idaho
southern Idaho
sorry should have been more specific.Car started life as a 383 with a 727 was converted to 440 4-speed so car has a 8 3/4 pretty sure the driveshaft is from the 383 727 combo.I have a shaft that I had built when I was running my jerico was just looking how much I may need to shorten it.
Re: A couple driveshaft questions [Re: moparcyco] #1202548
03/24/12 11:02 PM
03/24/12 11:02 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
383/727 should be either 45.85 inches [2BBL] or 45.60 inches [4 BBL]
If the d/shaft you have is either of those you should be good to go as is.
Re: A couple driveshaft questions [Re: pacifica] #1202549
03/24/12 11:54 PM
03/24/12 11:54 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
specs
Re: A couple driveshaft questions [Re: pacifica] #1202550
03/25/12 12:29 AM
03/25/12 12:29 AM
southern Idaho
southern Idaho
Cool thats what Iwas looking for.The shaft I'm currently using is toast the one I was refering to has ten drag strip passes on it. going to have it shortened because the jerico I was using was shorter than the 833.Thanks a bunch
Re: A couple driveshaft questions [Re: moparcyco] #1202551
03/25/12 12:54 PM
03/25/12 12:54 PM
With the rear axle on jackstands so the suspension is loaded I'd mockup your intended driveshaft selection & see how much end play you do have and if shortening one I'd butt it all the way forward/measure the C to C/subtract 3/4-7/8" if using the common flat aftermarket extension housing seal at the end of the trans
