915 Heads #1202434
03/24/12 11:24 AM
03/24/12 11:24 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Finally taking them into the shop. Can't find my old post with suggestions given. They will be going on a stock 440 69 Charger. Mild cam. All street use. Any suggestions as far as valves, springs, guides, etc.?
Grandma always said I had "hands of gold"!
Re: 915 Heads [Re: CHRGR69] #1202435
03/24/12 03:07 PM
03/24/12 03:07 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
2.14/1.81 valves. Use the springs rated for the cam you are using.
[image][/image]
Re: 915 Heads [Re: sgcuda] #1202436
03/24/12 07:16 PM
03/24/12 07:16 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
A little pocket porting will do wonders! Also the advantage of the closed chamber is in using it to build a quench motor. Get the quench as close to .040 as possible.
Re: 915 Heads [Re: R/T1968R/T] #1202437
03/25/12 07:35 AM
03/25/12 07:35 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Just be aware that if you end up going whole-hog on these (big valves, full machining) you'll be dangerously close to what a set ov new aluminum heads cost. Thats without even paying for porting. Pay for porting and you'll be over. I'd say if you already own the bigger valves, then do it, and port 'em enough to blend them in nicely. Make sure you machine the guide bosses for a higher lift cam, and something i would personally do, is machine the tops where the VC bolts up... they are always way off and the covers always leak.
If you dont own the valves already though, the costs to buy them and use them can add up quickly. By the time my (nice) core 915's left the shop, with (used) 'new' 2.14/1.81" valves, guides, seats, machining, a .030" shave, and cleaning and assembly i was out $900, including the price ov the cores. I wouldn't have bothered had i known, i would have saved another $300 and bought some aluminum.
And i agree vehemently with the above... you NEED zero-deck flat tops with closed chamber heads. Quench is good!
