valve train tick? #1201912
03/23/12 04:23 PM
03/23/12 04:23 PM
Minnesota
duster340 Offline OP
Minnesota
I would like some info on what is the best way to tell if pushrods and rockers are worn other than the obvious. I have a tick in my 340 duster and not sure if it is the valvetrain or maybe just header gasket?
Cory
Re: valve train tick? [Re: duster340] #1201913
03/24/12 02:44 AM
03/24/12 02:44 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
check p/r on a flat surface to see if bent .if rockers have many miles on them then mayby the cup end is bigger try and see if the p/r tip fits snuggly and go from there.
Re: valve train tick? [Re: duster340] #1201914
03/24/12 07:15 AM
03/24/12 07:15 AM
places
79powerwagon Offline
places
Headers you say? THAT'S your problem.
Re: valve train tick? [Re: 79powerwagon] #1201915
03/24/12 02:04 PM
03/24/12 02:04 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
You can use a stethascope (long screwdriver w the handle pushing your ear closed) to listen to different areas and pinpoint mrtal on metal noises. A piece of 3/8" oil line hose is good for listening to header leaks. If its a coiled hose its even better you can use the curved end to snake around and under the tubes. If its leaking you'll find it w/ the hose. Don't forget to check around the collector junction where the tubes meet for bad welds or cracks.
