440 intake fit #1201853
03/23/12 10:07 AM
03/23/12 10:07 AM
West Tennessee
rbstroker Offline OP
West Tennessee
Having an issue fitting an intake on a 440. I have tried three different intakes but all seem to sit too high even without the intake bathtub gasket. I am starting to think that the block has been decked. Is there an easy way to tell if I am correct or do I need to pull the heads?
Re: 440 intake fit [Re: rbstroker] #1201854
03/23/12 10:12 AM
03/23/12 10:12 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Either the block has been decked or the heads have been shaved. You may need to have the intake milled to fit. There may be a known outside measurement of each to compare, but I don't know what it is.
Re: 440 intake fit [Re: bobs66440] #1201855
03/23/12 10:19 AM
03/23/12 10:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what Bob said. Might have to cut it .030 I bought a new RPM years ago and had issues like that. I had it cut .030 and was able to use the paper and pan gaskets. If it fit's on top w/o any gaskets than yu can get away w/ the pan, but it sounds like it's still off. No big deal. You might be able to find one on e-bay already cut if you look hard.
Coming soon!!!!
Re: 440 intake fit [Re: Mr.Yuck] #1201856
03/23/12 10:38 AM
03/23/12 10:38 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
all the newer edelbrock intakes are too wide.
Re: 440 intake fit [Re: rbstroker] #1201857
03/23/12 10:42 AM
03/23/12 10:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Some shops will deck the block but not cut the valley end rails so one way to tell if the block has been cut a lot is to set the intake gasket in place and check the port and bolt hole alignment , it will be too high just like the intake .
What intakes are you trying to use ?
Re: 440 intake fit [Re: lewtot184] #1201858
03/23/12 10:28 PM
03/23/12 10:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
new 6-pack intake fit fine... but that's good to know.
Re: 440 intake fit [Re: Mr.Yuck] #1201859
03/23/12 11:44 PM
03/23/12 11:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Performer RPM I put on the 505" 440 stroker fit, and the block was even decked a bit.
I do have the M1 intake from my old 451" 400 block that was milled 0.100" on each side for it to fit.
Re: 440 intake fit [Re: rbstroker] #1201860
03/24/12 02:02 AM
03/24/12 02:02 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The easy way to tell is if your intake sits to high.
Most likely your heads were shaved since thats the easiest. But it could be a combination between the heads and the deck.
How close are your intake bolts to fitting or threading in. If its close, just drill them a little wider or slot them a little for better fitment.
