paint prep ? #1201439
03/22/12 04:19 PM
03/22/12 04:19 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i usaly use the dupont pre clean on paint prep or another auto paint similar product.is there a hardware store alternative?im not really concerned about savin a few bucks as i am the drive,nearest auto paint store 20 mi,hardware store 3 blocks.
Re: paint prep ? [Re: bonefish] #1201440
03/22/12 04:53 PM
03/22/12 04:53 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
On metal parts, I just wipe it down real good with laquer thinner and let it dry for a few minutes. Always cuts the grease/grime and evaporated quickly. I would imagine mineral spirits would work as well. Hell probably just about any solvent would work.
You would have to be more judicious on platic parts though...probably use the nice prep spray on those.
Re: paint prep ? [Re: cjskotni] #1201441
03/22/12 05:37 PM
03/22/12 05:37 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
im more concerned with wipeing down between paint coats.
Re: paint prep ? [Re: bonefish] #1201442
03/23/12 01:17 PM
03/23/12 01:17 PM
Jacksonville Florida
elitecustombody Offline
Why do you wipe between coats? You can use a tack cloth to pick up overspray,lint,dust,e.t.c. But if you must wipe between coats for whatever reason,use prep solvent that was made for automotive refinishing.
BTW, using lacquer thinner or acetone prior to paint is a bad idea.Because they both leave film behind,which can cause poor adhesion leading to chipping and peeling.
Use appropriate product if you want durable finish.
