easy main hoop question #1200839
03/21/12 01:44 PM
03/21/12 01:44 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
on the main hoop, the big part from rocker to roof- across the car and back to rocker, the supporting bar where a "seat belt" would install directly behind the driver going across the main hoop- what size does this need to be, i bought a chis alston kit for my barracuda and it came with a few extra bars... do i need to use the 1 3/4 or the smaller tube for this? I have enough to do either
Re: easy main hoop question [Re: 8urvette] #1200840
03/21/12 01:49 PM
03/21/12 01:49 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: easy main hoop question [Re: d7cook] #1200841
03/21/12 02:37 PM
03/21/12 02:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
It can be 1-1/4" minimum.
http://www.nhra.com/UserFiles/file/General_Regulations.pdf
Page 22
Make sure the crossbar is within four inches of the top of your shoulders when your in the seat, mine isn't and I have to have another bar added now
Re: easy main hoop question [Re: Cab_Burge] #1200842
03/21/12 04:20 PM
03/21/12 04:20 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Cab - you may be able to add a couple of vertical bar behind the driver seat rather than another cross bar. I did that as the beginnings of a funny car cage, but left the front section of the funny car cage off (could be added later if someone wanted to go faster than 8.50).
Re: easy main hoop question [Re: ProStDodge] #1200843
03/21/12 05:29 PM
03/21/12 05:29 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I have a chris alston cage in my dart I found out the 1 1/4 pipe didn't meat nhra specks for thickness may want to check it before you weld oit in.
Re: easy main hoop question [Re: Cab_Burge] #1200844
03/21/12 10:27 PM
03/21/12 10:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Page 22
1 1/4" is ok for the cross bar and per my RCI belt instructions, shoulder mounting should be 4" or less below the the top of the shoulder line. I put my seat in first, before I welded in my cross bar to make sure I was within that 4" distance.
Fastest 300
Re: easy main hoop question [Re: Crizila] #1200845
03/21/12 11:27 PM
03/21/12 11:27 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
awesome, thanks guys
1 more
the braces that go from the main hoop to the subframe- the short diagonal ones. 1 1/4"? or 1 3/4"?
i didn't see anything about it in the link provided above
Re: easy main hoop question [Re: 8urvette] #1200846
03/22/12 01:36 AM
03/22/12 01:36 AM
Pound, Va
Chris Vanover Offline
Pound, Va
1 1/4
Re: easy main hoop question [Re: ProStDodge] #1200847
03/22/12 01:40 AM
03/22/12 01:40 AM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Nice work.
Re: easy main hoop question [Re: Chad Bittle] #1200848
03/22/12 02:03 AM
03/22/12 02:03 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
and for last one now, i know common sense says i should center the 6x6 plate under the roll bar... but what if i do not have room to center the plate???? i do not see any where in the NHRA general regulations where is states this?
so is this common practice but not actually required?
Re: easy main hoop question [Re: 8urvette] #1200849
03/22/12 02:12 AM
03/22/12 02:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No it doesnt have to be centered... your spreading
the load out with the thicker plates vs just putting
the tube on floor pan sheet metal
Re: easy main hoop question [Re: MR_P_BODY] #1200850
03/22/12 03:04 AM
03/22/12 03:04 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
FANTASTIC!!!!!
Thanks for you help guys. should get some work done on it this weekend... after re-building 2 fences.
