Eddy 1406 accel pump parts ? #1200447
03/20/12 07:54 PM
03/20/12 07:54 PM
RapidRobert Offline OP
Went too long between teardown/rebuild. Under the cluster/gasket is there just the brass rod or is there a check ball below or on top of the rod. The kit had a ball but it may go in the pump inlet assy which I did not unscrew or elsewhere???. Thank you for your time
Re: Eddy 1406 accel pump parts ? [Re: RapidRobert] #1200448
03/20/12 08:03 PM
03/20/12 08:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Edelbrock has the manual on their site, for free.
That being said, and it's been a few years, it should have a ball under the rod in the cluster passageway. I accidentally dropped that ball into my intake when I was troubleshooting a pump shot issue. Eventually, the 318 coughed it out but I wasn't gonna tear the engine down for it. IOW, I distinctly remember that ball.
Don't be the exception.
Re: Eddy 1406 accel pump parts ? [Re: Supercuda] #1200449
03/20/12 09:52 PM
03/20/12 09:52 PM
Central TX
roe Offline
roe  Offline
Central TX
I just took mine apart on Saturday to clean it and adjust the floats. The checkball is under the rod.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Eddy 1406 accel pump parts ? [Re: roe] #1200450
03/20/12 11:15 PM
03/20/12 11:15 PM
Thanks guys
