advantages of electric fuel pump #1200325
03/20/12 05:14 PM
03/20/12 05:14 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Im having a FAST legal stroker 340 built for my 71 roadrunner. Just wondering what everyones thoughts were of electric fuel pump vs. mechanical for this application. If I were to do electric, Id probably get a in-tank pump. I know vapor lock would be a worry with mechanical, but if the motor keeps around 180*, it wouldn't be a problem, right? thanks in advance!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: advantages of electric fuel pump [Re: mopars_1] #1200326
03/20/12 05:21 PM
03/20/12 05:21 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Better to have the weight in the back, even if its just a little!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: advantages of electric fuel pump [Re: fed] #1200327
03/20/12 07:57 PM
03/20/12 07:57 PM
southwest pa
bodyworks racing Offline
southwest pa
It takes hp to turn the mechanical pump albiet a small amount they can add up
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: advantages of electric fuel pump [Re: bodyworks racing] #1200328
03/21/12 12:05 PM
03/21/12 12:05 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thanks for the responses. anyone else want to chime it? thanks!
-kevin
1937 Plymouth PT50
Re: advantages of electric fuel pump [Re: mopars_1] #1200329
03/21/12 12:34 PM
03/21/12 12:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
And you don't have to worry about the diaphram going and pumping gas into your oil pan!
Re: advantages of electric fuel pump [Re: Dodgem] #1200330
03/21/12 12:46 PM
03/21/12 12:46 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
advantages are many, one not listed yet, is no more cranking the engine to prime the fuel bowls if the engine has been sitting for awhile. just let the pump run to fill the bowls.
one disadvantage is that if you do not have your pressure set properly with a regulator, you can push fuel past the needle and seat, and you'll flood the engine, wash down cylinder walls and kill your rings.
**Photobucket sucks**
Re: advantages of electric fuel pump [Re: 70Cuda383] #1200331
03/21/12 10:14 PM
03/21/12 10:14 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Its always better to push fuel than suck it
Re: advantages of electric fuel pump [Re: emarine01] #1200332
03/21/12 10:58 PM
03/21/12 10:58 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
no support for mechanical? anyone want to play devils advocate?
1937 Plymouth PT50
Re: advantages of electric fuel pump [Re: mopars_1] #1200333
03/22/12 09:41 AM
03/22/12 09:41 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
OK, I'll bite -
I've never heard anyone complain of a noisy mech pump.
If using an electric, make sure to put some safety interlocks to shut it off in case of an accident.
