Air Grabber Not Working
#1199949
03/19/12 11:12 PM
03/19/12 11:12 PM
Posts: 1,286 IN
GTX4spd
IN
When I got my '70 GTX out recently, the A/G didn't work properly. It raises up about a 1/4 inch, but no more. Is the problem likely in the actuator? Or the switch? Or somewhere else? Appreciate any help, thanks!
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: Air Grabber Not Working
[Re: Sinitro]
#1199951
03/20/12 10:53 AM
03/20/12 10:53 AM
Posts: 1,286 IN
GTX4spd
IN
Hmmm..... hadn't thought of that, thanks. I'll try that when I get time. At least that would rule the actuator in or out.
[Re: GTX4spd]
#1199952
03/20/12 01:08 PM
03/20/12 01:08 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Inspect your hoses closely....I had a mouse chew through mine a few years back during winter storage. The damage was just outside the firewall.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: GTX4spd]
#1199953
03/20/12 03:08 PM
03/20/12 03:08 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Take the hood off and give to me! On a more serious note, it is likely a vacuum leak. Could be a bad line as mentioned above, or could be a slight crack at one of the connection nipples on the back of the switch (old switches get brittle). Good luck!
[Re: GTX4spd]
#1199954
03/20/12 05:16 PM
03/20/12 05:16 PM
Posts: 704 USA
rftroy
USA
Check for mechanical interference as well, especially if there have been modifications made in the engine compartment. The actuating rod for the scoop could be making contact with an object under the hood.
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1199955
03/21/12 12:22 AM
03/21/12 12:22 AM
Posts: 1,286 IN
GTX4spd
IN
I've inspected the hoses, didn't find anything, & nothing under the hood has been changed that would cause interference, plus I've run it with the hood open while trying to find the problem. And I'm really hoping it's not the switch, mostly because these brittle old bones don't contort under the dash as well as they used to!
