replacement hemi cam #1199359
03/19/12 12:51 AM
03/19/12 12:51 AM
California
mickm Offline OP
mickm  Offline OP
California
have a friend with a 68, all stock including exhaust manifolds. the cam is wiped, at least 2 lobes/lifters are bad. he is wondering if there are better than stock grinds out there, that will still give the same idle and driveabilty, but some better performance, and also keep the stock springs.
anyone have any thoughts?
Re: replacement hemi cam [Re: mickm] #1199360
03/19/12 03:43 AM
03/19/12 03:43 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Considering he is into a total rebuild because of the metal contamination, have him contact Chase Knight on here, he is a Crane cams rep. for a recommendation. I would run a solid roller with 66550-16 oil feed lifters and use pushrod oiling. No more wiped cam lobes and better performance. Tim
