hi,
i'm just getting around to installing the 3/8th vent line from the tank to the breather. there is a section of line that comes up from the along side the frame rail up inside the engine compartment, and the rubber hose from the breather connects to this.
i have reproduction fuel lines from fine lines, and to this point they fit really well. i'm wondering about this last section though, as where it goes around and underneath the frame rail it seems to stick out a little far from the frame rail. doesn't contact anything, so should be fine, but still wondering.
anyway, the real question is attaching this section of the line. there is one clip on the car that looks like it is for this, but only one. up along the inner fender there is a hole very close to where this line runs, but the clips i got from fine lines are too big to fit that hole.
was wondering if anyone could give me a description of where and how this line is held in place, or has some pictures.
thanks!
