Cuda horns
#1199038
03/18/12 06:10 PM
03/18/12 06:10 PM
Posts: 1,487 STL
cdstl
STL
When the last guy took out the horns in my 72 Cuda he just cut the wires off by the horns. How would I splice the female ends onto the Dark Green/Red wire that is hanging there so that it goes to both horns. I have an idea but everyone's input would help.
Also would anyone have a picture of how they are mounted on the radiator support?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cuda horns
[Re: cdstl]
#1199039
03/19/12 12:16 PM
03/19/12 12:16 PM
Posts: 1,487 STL
cdstl
STL
I heard that member name Anlauto would be a good source, so would burdar and 19cuda73. Any ideas guys?
Re: Cuda horns
[Re: UCUDANT]
#1199041
03/19/12 03:39 PM
03/19/12 03:39 PM
Posts: 1,487 STL
cdstl
STL
Hmmm, that explains the hookup. Pretty straighforward. Wouldn't mind seeing a picture with the Spartons mounted, though.
Thanks Bob
Re: Cuda horns
[Re: cdstl]
#1199045
03/19/12 09:53 PM
03/19/12 09:53 PM
Posts: 344 PA
noplanb
PA
Really hard to get in there with the car assembled, but the horns mount on the header panel vertical support, facing the driver side. Here's the driver side view:
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Cuda horns
[Re: noplanb]
#1199046
03/19/12 09:54 PM
03/19/12 09:54 PM
Posts: 344 PA
noplanb
PA
And the passenger side. Once you get everything in place and play with the positions it makes sense. HTH.
Re: Cuda horns
[Re: cdstl]
#1199047
03/19/12 10:38 PM
03/19/12 10:38 PM
Posts: 1,487 STL
cdstl
STL
Thanks for the help guys, I got 'em in and really no big deals since the mounting bracket has a little tang that keeps them from twisting on the header panel support. Just had to look for a big hole with a little hole next to it.
Now I just have to get a horn relay.
Re: Cuda horns
[Re: cdstl]
#1199048
03/19/12 10:44 PM
03/19/12 10:44 PM
Posts: 1,487 STL
cdstl
STL
Bob (Ucudant),
If I'm not mistaken these are the 72-74 horns that they used on the Cuda. One Hi and one low. edit: They are painted with Krylon satin black which is REAL close to the black plastic that the "horn section" is made of.
Chuck
