Cuda horns #1199038
03/18/12 06:10 PM
03/18/12 06:10 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
When the last guy took out the horns in my 72 Cuda he just cut the wires off by the horns. How would I splice the female ends onto the Dark Green/Red wire that is hanging there so that it goes to both horns.
I have an idea but everyone's input would help.
Also would anyone have a picture of how they are mounted on the radiator support?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cuda horns [Re: cdstl] #1199039
03/19/12 12:16 PM
03/19/12 12:16 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I heard that member name Anlauto would be a good source, so would burdar and 19cuda73. Any ideas guys?
Re: Cuda horns [Re: cdstl] #1199040
03/19/12 01:44 PM
03/19/12 01:44 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Mine is butchered too I figured I'd find a harness from a similar Mopar and cut it up high after pulling back the loom and splice it in (correctly) but pics and info would be nice.... HEY DENNIS EDIT hmmmm let me check a parts manual
Re: Cuda horns [Re: UCUDANT] #1199041
03/19/12 03:39 PM
03/19/12 03:39 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Hmmm, that explains the hookup. Pretty straighforward. Wouldn't mind seeing a picture with the Spartons mounted, though.
Thanks Bob
Re: Cuda horns [Re: cdstl] #1199042
03/19/12 03:43 PM
03/19/12 03:43 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
On a Challenger...I don't know if Cuda's mount them the same way.
Re: Cuda horns [Re: burdar] #1199043
03/19/12 04:11 PM
03/19/12 04:11 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I checked my pictures and did not get a good shot like this for my car. Darrens photo is right on. It seems to me that as I remember the hookup and wire routing went pretty smooth from the harness. Will double check today.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cuda horns [Re: 19cuda73] #1199044
03/19/12 04:32 PM
03/19/12 04:32 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Here's a vague factory diagram
Re: Cuda horns [Re: cdstl] #1199045
03/19/12 09:53 PM
03/19/12 09:53 PM
PA
noplanb Offline
noplanb  Offline
PA
Really hard to get in there with the car assembled, but the horns mount on the header panel vertical support, facing the driver side. Here's the driver side view:
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Cuda horns [Re: noplanb] #1199046
03/19/12 09:54 PM
03/19/12 09:54 PM
PA
noplanb Offline
noplanb  Offline
PA
And the passenger side. Once you get everything in place and play with the positions it makes sense. HTH.
Re: Cuda horns [Re: cdstl] #1199047
03/19/12 10:38 PM
03/19/12 10:38 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks for the help guys, I got 'em in and really no big deals since the mounting bracket has a little tang that keeps them from twisting on the header panel support. Just had to look for a big hole with a little hole next to it.
Now I just have to get a horn relay.
Re: Cuda horns [Re: cdstl] #1199048
03/19/12 10:44 PM
03/19/12 10:44 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Bob (Ucudant),
If I'm not mistaken these are the 72-74 horns that they used on the Cuda. One Hi and one low.
edit: They are painted with Krylon satin black which is REAL close to the black plastic that the "horn section" is made of.
Chuck
Re: Cuda horns [Re: cdstl] #1199049
03/19/12 10:58 PM
03/19/12 10:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe they were dipped in gloss black paint from the factory. Yes, one half is a flat black plastic but it got dipped with the rest of the horn. My original horns still had a lot of paint on the plastic section.
Re: Cuda horns [Re: burdar] #1199050
03/20/12 10:15 PM
03/20/12 10:15 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Wow, I have a Barracuda and a Challenger. Both have the horns mounted PS just behind the radiator support. Mine may be wrong...
Re: Cuda horns [Re: Vert] #1199051
03/20/12 10:20 PM
03/20/12 10:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The horns were moved starting in 72 because the charcole canister was mounted where the horns used to be.
