What is the best way to remove paint from emblems? #1198742
03/18/12 12:42 AM
03/18/12 12:42 AM
SC
V194 Offline OP
V194  Offline OP
SC
Since they are chrome with paint in the recessed areas I would like to blast them but will any blasting media degrade the chrome?
Can one use glass bead or soda (baking soda) and keep the chrome undamaged?
Re: What is the best way to remove paint from emblems? [Re: V194] #1198743
03/18/12 01:16 AM
03/18/12 01:16 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
I just used paint stripper from Home depot the one that comes with the spray bottle. To re-paint it I just sprayed the whole thing with spray can black. Before it cures all the way I rubbed the emblem accross a rag on a hard surface. I used OMNI MS251 paint gun cleaning solvent but paint thinner will work too. Just put a little bit on the rag and don't fold the rag. Then let the emblem dry and install.
Re: What is the best way to remove paint from emblems? [Re: GreenGlow] #1198744
03/18/12 01:26 AM
03/18/12 01:26 AM
SC
V194 Offline OP
V194  Offline OP
SC
I just used paint stripper from Home depot the one that comes with the spray bottle. To re-paint it I just sprayed the whole thing with spray can black. Before it cures all the way I rubbed the emblem across a rag on a hard surface. I used OMNI MS251 paint gun cleaning solvent but paint thinner will work too. Just put a little bit on the rag and don't fold the rag. Then let the emblem dry and install.
I never have good success with stripper because it never comes out of the crevices completely, It tends to build up in tight corners.
Re: What is the best way to remove paint from emblems? [Re: V194] #1198745
03/18/12 07:53 AM
03/18/12 07:53 AM
IN
ahy Offline
ahy  Offline
IN
A tooth brush with strong solvent will get it out of the corners... just use good gloves.
Re: What is the best way to remove paint from emblems? [Re: V194] #1198746
03/18/12 08:06 AM
03/18/12 08:06 AM
places
79powerwagon Offline
places
soda blasting.
