Ok, I just finished installing my fresh Copes Pro-Street trans and started to adjust the kickdown. I installed a bolt and nut in the kickdown slot because my factory rods were not long enough to work with the new Carb/intake combo.
Heres the problem. If I adjust the kickdown so the lever is all the way back at WOT. Then it will have about 1/2" play at idle position. And the other way around also. If I adjust the linkage so the kickdown lever is at full forward position at idle, then it will have about a 1/2" play at WOT.
It's as if I need a different intermediate lever with the rod attachment farther out!
What am I missing here?
From what I see, I cant have it both ways. Lever forward at idle, lever back at WOT. It's one or the other and I have to compromise.
But which way should I compromise?
