Hemi fan spacer #1198075
03/16/12 08:32 PM
03/16/12 08:32 PM
IL
66HEMICORONET Offline OP
IL
Can anyone tell me which fan spacer I would need to run on my 66 Hemi? The fan is a 4 blade direct drive fan part# 2265034. I've got it narrowed down to either part 1.24" spacer part# 1825932 or the 1.06 spacer witch is part# 1851959. Any help would be great. Thanks.
Re: Hemi fan spacer [Re: 66HEMICORONET] #1198076
03/16/12 09:34 PM
03/16/12 09:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I can't answer which one - my '68 uses a fan clutch - but if you have a shroud, you can mock up your fan position using some long bolts. If the blade depth is centered at the shroud opening (1/2 in, 1/2 out) you're good.
Re: Hemi fan spacer [Re: topside] #1198077
03/16/12 09:53 PM
03/16/12 09:53 PM
IL
IL
Thanks for the input. I will remember this in case I can't figure it out. The engine is not in car as of now we are rebuilding so the mock up would be hard.
Re: Hemi fan spacer [Re: 66HEMICORONET] #1198078
03/17/12 04:00 AM
03/17/12 04:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
GG's "white book" shows '66 & early-'67 HEMI to be #1825 932 (1.24").
- IMO the parts catalogs are NOT very helpful.
1966 Chrysler Parts Catalog (March '67 revision) shows: (b-body w/V8)
7-02-16 w/o Air Cond., except 273 and 318 cu. in. Eng. - 1730 155
****** w/Air Cond., Field Installation, w/High Perf. - 2003 059
****** w/o Air Cond. - 1851 959
1967 Chrysler Parts Catalog (March '67 revision) shows: (b-body w/V8)
7-02-16 w/o A/Cond., w/383, 426 and 440 cu. in. Eng. - 1851 959
Re: Hemi fan spacer [Re: 6bblgt] #1198079
03/17/12 09:51 AM
03/17/12 09:51 AM
IL
IL
Thanks for the help. Going to try and locate a 1.24" spacer. The bolt kit I have says for the 1.24" spacer but things kinda contradict themselves sometimes just needed to be sure.
Re: Hemi fan spacer [Re: 66HEMICORONET] #1198080
03/17/12 11:05 AM
03/17/12 11:05 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Use what you have,.018 won't even be noticeable,I doubt anyone is going to measure it.
Re: Hemi fan spacer [Re: 62maxwgn] #1198081
03/17/12 08:27 PM
03/17/12 08:27 PM
IL
IL
The car was missing the fan and fan spacer when we purchased it. If anyone knows where i can get a correct spacer let me know. Thanks.
Re: Hemi fan spacer [Re: 66HEMICORONET] #1198082
03/17/12 08:40 PM
03/17/12 08:40 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, the fan blade itself was a non clutch style 4 blade solid fan (same as used on a /6!)
Re: Hemi fan spacer [Re: ScottSmith_Harms] #1198083
03/17/12 09:42 PM
03/17/12 09:42 PM
IL
IL
Thanks Scott I just got one for it this week and it is a 4 blade fan part#2265034. Just need a spacer and will be good to go. Also I e-mailed you earlier about rebuilding the distributor. I need the rest of the e-mail address for Frank. Missing the @ part.
Re: Hemi fan spacer [Re: 66HEMICORONET] #1198084
03/18/12 12:06 AM
03/18/12 12:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
