not running smooth #1198000
03/16/12 04:00 PM
03/16/12 04:00 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
My 95 Dodge Ram just will not run smooth. It has 125000 miles and seems to be in good shape. I changed the oil and filter, the air filter and replaced the plugs. The old plugs looked good as does the wires. What do I need to check now?
Re: not running smooth [Re: Tadams] #1198001
03/16/12 04:03 PM
03/16/12 04:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ever replace the timing chain?
Coming soon!!!!
Re: not running smooth [Re: Tadams] #1198002
03/16/12 04:14 PM
03/16/12 04:14 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
When you say "plugs look good", have you checked the gap? Ever done a compression check? Have you checked the ECU for fault codes? Just something to get you started.
Re: not running smooth [Re: moparjo68] #1198003
03/16/12 06:27 PM
03/16/12 06:27 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Plugs were gapped correctly. The old ones were not dirty or oil covered. The timing chain has been replaced, but I don't remember exactly how long ago, maybe a year, but not that many miles have been driven in that time. There are no codes showing. I
used the truck for errands until about 8 weeks ago when I went back to work. I drive now 50 miles a day 3 days a week.
Thanks for your help.
Re: not running smooth [Re: Tadams] #1198004
03/18/12 10:42 AM
03/18/12 10:42 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
if the 125k mile truck has orig.plugs,wires dist.cap.i would replace them all to start with.complete tune up too start with.
Re: not running smooth [Re: mcmopars] #1198005
03/18/12 01:10 PM
03/18/12 01:10 PM
Central TX
roe Offline
roe  Offline
Central TX
Maybe the wires. I thought my wires were still good but they were shot. New wires took care of a crappy idle and running real shaky when dropping the hammer. Seemed to do it only under a heavy load so the typical pop the hood in the dark and look for a light show didn't show me the wires were bad.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
