Edelbrock Thunder AVS carbs #1197746
03/15/12 09:31 PM
03/15/12 09:31 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Just rebuild the engine in my dad's 69' Fury convertable. He wanted a four barrel carb upgrade. So I got an old Edelbrock performer intake and milled the name off and painted it like stock. Got the engine in car with a Holley 650 vacuum secondary that came with a metering block on the rear for additional tuning. Bought carb off Ebay. Turns out everything had to be moved around to accomodate the Holley. And now the Holley proves to be junk car ran terrible. Put the original 2 barrel back on and every thing runs fine. But, really want to make the switch. Was hearing the Carter Thunder AVS was a great little street carb.
This is a 383 with a cam ground for mileage and a little bowl work behind the valves. Should I rely on the CFM calculator and buy the 500 CFM sense the car is not driven for performance or get the 650 which may give a little more performance on that occassional two lane road sling shot pass?
Leon
Re: Edelbrock Thunder AVS carbs [Re: Leon441] #1197747
03/15/12 10:17 PM
03/15/12 10:17 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
650 AVS is the PERFECT carb for that application.
Sheldon
Re: Edelbrock Thunder AVS carbs [Re: RUNCHARGER] #1197748
03/16/12 11:48 PM
03/16/12 11:48 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The 650 AVS is a nice carb. I had to jet it up and put bigger accelerator pump nozzles on mine to get it to run right on my stock 340 with heat blocked off of intake. But once it was tuned I loved it.
Re: Edelbrock Thunder AVS carbs [Re: 69Cuda340S] #1197749
03/17/12 12:49 AM
03/17/12 12:49 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Did you also go up from .098 secondary jets to say .100? I know I had to go up 8 percent rich on cruise and wide open but I didn't go up on the secondaries. Wondering if I should have! Don't mean to hijack the original post! I just needed to know this! Thanks!
Re: Edelbrock Thunder AVS carbs [Re: superbeedave] #1197750
03/17/12 03:16 PM
03/17/12 03:16 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Has anyone tried a 500 CFM Edelbrock Thunder AVS?
Or did everyone just assume they needed the 650. Reason I ask is at 5,000 RPM which is about all this engine will ever turn a 500 CFM should be plenty. Reading the post and seeing that guys are going up on squirters and jets......Well that is a tell tell sign the carburator is too big.
Does anyone know the size of the original 4 barrel for a 383 from the factory?
Leon
Re: Edelbrock Thunder AVS carbs [Re: Leon441] #1197751
03/17/12 03:59 PM
03/17/12 03:59 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I think the 500 is too small because in normal driving the primaries won't feed it enough. So the mileage will get worse because you'll be using the secondaries whereas with a 650 it would be running on the primaries more.
Sheldon
Re: Edelbrock Thunder AVS carbs [Re: RUNCHARGER] #1197752
03/17/12 04:03 PM
03/17/12 04:03 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I know guys who have ran a 500 CFM AFB on a 440. Back in the days of decent fuel, he was getting high teens for mileage. You will sacrifice some top end power, but should be stout on the bottom. For a mileage oriented build I would totally go with one.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Edelbrock Thunder AVS carbs [Re: herkamer] #1197753
03/17/12 06:12 PM
03/17/12 06:12 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i think i read somewhere early 340 was about 485 or 500 cfm and early 440 was 585 cfm.
many different opinions on carb size!
Re: Edelbrock Thunder AVS carbs [Re: can.al] #1197754
03/17/12 08:24 PM
03/17/12 08:24 PM
dogdays Offline
dogdays  Offline
If you are leaning towards the 500, go for it. It will have really sharp throttle response and you'll lose a few hp up top but the carb is good for at least 300 real hp.
R.
Re: Edelbrock Thunder AVS carbs [Re: dogdays] #1197755
03/17/12 08:27 PM
03/17/12 08:27 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
max wedge motors had 2- 500cfm AFB's for a race motor.
Re: Edelbrock Thunder AVS carbs [Re: Leon441] #1197756
03/17/12 09:17 PM
03/17/12 09:17 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The 340, 383 and non-hp 440 all used the smaller Carter AVS from the factory. The HP 440 used the large AVS (some came with Holleys). This would be before the Thermoquad era.
On an engine that's not going to see high rpms or trips down the 1/4, I'd consider the smaller Thunder for a stronger low end.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Edelbrock Thunder AVS carbs [Re: GO_Fish] #1197757
03/17/12 11:54 PM
03/17/12 11:54 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
My '70 Bee had a 335HP 383. The stock Holley on it was less than 500cfm. I have a couple of Carters that came on the single quad 426 wedge motors. Less than 500cfm.
I put a 625 Carter on it and picked up some power and MPG's! Also went with a Street Dominator.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Edelbrock Thunder AVS carbs [Re: Rug_Trucker] #1197758
03/18/12 10:46 AM
03/18/12 10:46 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
You'll be happy with the 500cfm. Its a great carb.
