Re: 383 Pistons: L2315 or stock?
[Re: JohnRR]
#1197561
03/15/12 09:06 PM
03/15/12 09:06 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
How far are your current pistons in the hole ? forget about quench , you'll have none with 906 heads unless they have been cut, at 92 cc yours have not. 2315's with be .015 in the hole on a stock deack block , these will be very close to what actually was installed in your 1970 383 .
The downside to what you currently have is your compression ratio is going to barely be 9.0 , probably less , use the stock .021 steel shim head gasket or it will be even lower .
The pistons arn't in the engine for me to measure how deep they set, but how do you figure the L2315's are closer to what the stock pistons were? I thought the original (real) compression ratio of those engines was like 8.1 or 8.2.
[Re: VoodooCLD]
#1197562
03/16/12 12:15 PM
03/16/12 12:15 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The 71 383 has a LOWER advertised compression ratio than the 68-69 which I am well versed in , I could probably recite it's specs in my sleep , Chrysler adjusted compression ratio by sinking the piston in the bore , lower compression ratio means a piston deeper in the hole . Remember 383 piston selection sucks , the different aftermarket makers each basically sell ONE piston to cover all years of the B deck 383 even though these engines came with different compression ratios and different cylinder head configurations .
[Re: VoodooCLD]
#1197564
03/17/12 01:54 AM
03/17/12 01:54 AM
JohnRR
U.S.S.A.
ahhh, i see. So stock for 68-69, not for 71
No they are a compromise. I don't think they are stock for any particular era , a compromise to cover them all . Maybe stock for the early closed chambered head engines ??
