Re: Bench top sealing
[Re: MadMatt]
#1197490
03/15/12 05:51 PM
03/15/12 05:51 PM
Posts: 1,605 westerly, ri. usa
440lebaron
westerly, ri. usa
nice good coat of marine varnish
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Stanton]
#1197492
03/15/12 06:36 PM
03/15/12 06:36 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
you might want to try this but i warn you it's addictive. www.garagejournal.com
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: topside]
#1197496
03/15/12 09:11 PM
03/15/12 09:11 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I was just thinking maybe linoleum or vinyl floor tiles. Any thoughts on that?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
[Re: MadMatt]
#1197497
03/15/12 11:05 PM
03/15/12 11:05 PM
Posts: 20,755 A collage of whims
topside
A collage of whims
Both of those materials gouge fairly easily, seams trap liquids, and they probably won't like solvents, but for something that would be kept clean & dry and not pounded on, peel & stick tiles would work and there are a lot of color options...heck, faux slate would be amusing...all depends on what you're going to use the surface for. For that matter, think about what's going under the bench before you set a shelf height, or make it adjustable. Start looking for wall cabinets, too, so I don't have to bust your stones when I inspect the place!:)
[Re: topside]
#1197500
03/16/12 01:56 AM
03/16/12 01:56 AM
Posts: 1,187 USA
big-block-dave
USA
No bare wood, i used 3/4" plywood and put a clear finish on it like polyurethane. With clear just a damp rag wipes up the dust/dirt. Wipe grease/oil rite off. I use old cafeteria plastic trays when working on like a carb or what ever might have chemicals or gas. Bare wood will look like crap once the dust and dirt sits/works into it.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: MadMatt]
#1197504
03/16/12 01:46 PM
03/16/12 01:46 PM
Posts: 3,880 Oregon
hooziewhatsit
I put some left-over linoleum on the bench at my previous place. Seemed to work pretty well, and not too hard to get clean. It was starting to stain in a few places by the time I moved though. I may just varathane the next work bench I build
[Re: MadMatt]
#1197507
03/18/12 10:32 PM
03/18/12 10:32 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I coated my bench tops with roll on truck bed liner. It's really durable and wipes clean. Seems to be chemical resistant too. One great tip I got when making my benches was to make the top easily replaceable. Use a thin final layer of plywood or OSB that you simply pull off and flip over or replace when it gets too trashed.
Paul '69 Super Bee 383 EFI Turbo
