Paint over ceramic header coating? #1197432
03/15/12 10:51 AM
03/15/12 10:51 AM
Maryland
mrob Online content OP
mrob  Online Content OP
Maryland
I know I'm being a cheap-ass, but has anyone had any luck painting over the ceramic coating on headers? Why may you ask - because the ceramic coating on my Hooker 5903 headers now has small rust pimples (especially around part where the header flange and pipes meet). I'm not looking for anything perfect, but would a high-temp paint stick to the ceramic coating or am I just wasting my time?
Re: Paint over ceramic header coating? [Re: mrob] #1197433
03/15/12 10:52 AM
03/15/12 10:52 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Good question actually...
Re: Paint over ceramic header coating? [Re: moparpollack] #1197434
03/15/12 10:57 AM
03/15/12 10:57 AM
dogdays Offline
dogdays  Offline
It'll stick until it slides off.......
Seriously, give it a try. It just might work.
R.
Re: Paint over ceramic header coating? [Re: mrob] #1197435
03/15/12 12:24 PM
03/15/12 12:24 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Prep them just like you would painting bare headers and you will be fine.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Paint over ceramic header coating? [Re: mrob] #1197436
03/15/12 04:33 PM
03/15/12 04:33 PM
Maryland
Maryland
One reason I think it may work is because some overspray is still sticking to the collectors from when the car was painted. That's not high temp paint - just a catalyzed urethane auto paint. It hasn't peeled or blistered off in about 2 years.
One guy replied back that I should prep as though the headers were bare. I usually scuff bare metal tubes with a Scotchbrite pad, clean them really well and then shoot them with high temp paint. Same thing for the ceramic coating? Don't know how hard that coating really is. Maybe it would be better to lighty sandblast?
Re: Paint over ceramic header coating? [Re: mrob] #1197437
03/15/12 04:38 PM
03/15/12 04:38 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Barbeque paint, works like a charm, stick to anything w/ minimal prep, and its rust resistant too.
Re: Paint over ceramic header coating? [Re: mrob] #1197438
03/16/12 08:17 AM
03/16/12 08:17 AM
bigsbigelow Offline
bigsbigelow  Offline
Try the Scotch-Brite. I usually start with something like ~120 grit to scuff bare metal. All you need is enough scuff for the paint to mechanically bond to but if you use high temp paint, it will need to "bake on" (the first time you run the engine) to cure anyways.
Re: Paint over ceramic header coating? [Re: mrob] #1197439
03/16/12 10:34 AM
03/16/12 10:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
OVERSPRAY sticks to anything its not supposed to be on regardless of the surface.
Re: Paint over ceramic header coating? [Re: bonefish] #1197440
03/16/12 12:37 PM
03/16/12 12:37 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you wrap your headers, you can soak the wrap with high temp paint and it makes the wrap into one piece that won't fray. Tim
