318/340 carb stud and nut interchange? #1197109
03/14/12 05:55 PM
03/14/12 05:55 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Can anyone tell me if the carb stub and nut from a 1971 challenger 318 2 barrel is the same for a 72 340.
Dantes is out of stock and I have the old set up from my 318, wondering if it will work??
Jims Auto parts has this listed and it makes me think they are the same.
CARBURETOR TO THROTTLE CABLE STUD
(for mounting accelerator cable & auto kickdown linkage & throttle return spring)
EG-1049 Auto Trans 2 or 4 Barrel $ 24.95 ea.
http://jimsautoparts.com/engine_fuel_parts.htm
Thanks again for the help
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: 318/340 carb stud and nut interchange? [Re: fireeng] #1197110
03/14/12 06:14 PM
03/14/12 06:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It should be the same...
Re: 318/340 carb stud and nut interchange? [Re: fireeng] #1197111
03/14/12 07:14 PM
03/14/12 07:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it is the same , same part for all engines .
And haven't read enough bad things to not even bother going to Jim's ?
